Need parts for a Insley
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Topic: Need parts for a Insley
    Posted: 07 Mar 2011 at 1:19pm
Need some help trying to find where to get parts for a H1000 track hoe. Use to be able to get them from WC Sales Inc in Aurora, Il but haven't been able to contact them. Its been a couple year since we had to get anything from them and now can't get a hold of them so dose anyone know if they still exist and what their number is, tried the one on the website but doesn't work http://wcsalesinc.com/, tried emailing but no reply. I'm needing a pump so if anyone knows where else may have parts for them any help would be appreciated.
If fishing is a sport your looking at an athlete
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 2:33pm
hyd pump, inj pump or ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 3:43pm
http://www.badgerequipment.com/about/history-badger-equipment.php
Says Insley was bought out or is owned by the outfit above now.
 What make pump is it , as it seems most pumps are made by just a few mfg when it comes to excavators.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 8:02pm
Its a hydro pump. Ill have to check further on what make it is. Its not actually my hoe but a buddy of mines but I help them with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 9:09pm
Kawasaki was a large supplier of pumps for machines , but like my friend who has a 690 JD hoe he found a full machine cheaper than JD wanted for the pump he needed for his.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 7:53am
Coke price is one of the keys to this machine. They got an estimate from a guy for 10000 to clear a fence row out. I found this machine on Craigslist for 5600, so it will bring more at a scrap yard right now. The 2 rams to lift the boom and the part where the machine swings leaked real bad but we done fixed that for less than $400 and its got a Detroit that runs like a top. The only problems now is one pin in the tracks has a bushing out and the bucket wants to leak down. So he had gauges on the pump testing the pressures to the bucket seeing if the problem was there or in the packing and thats when the pump blew. So they can afford some repairs with what they got invested. Even though its not wore out we go by the modo, a wore out hoe is better than no hoe at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 10:16am
Can try Rock and Dirt site for parts also as they have a listing of lot of places which might have things for it .
 Can also try place lit Thill Trach and Tractor in Eau Claire WI to see if they have locator on things you might need.
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 10:43am
Check to see if Rodger Gerhart has any. Great guy to work with. My great-uncle used to work for him back in the day, boy do they have stories! He mostly deals in older cranes and dozers but might have one for a newer excavator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 11:14pm
Thanks for the info guys and the best we can figure the machine is from the late 70s, but the previous owner completely repainted it so it looks new.
