B Front Spindle Brg/Seal Question
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Topic: B Front Spindle Brg/Seal Question
    Posted: 06 Mar 2011 at 8:20pm
I replaced the front wheel bearings and OEM type seals on a pair of B spindles, and the seals seem really snug. I lubed them well, as well as the inside of the hubs, but they are stiff when I turn the hubs. Is this normal?
are genuine." - Mark Twain
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 8:26pm
I had same problem, mine wanted to turn in hub and not at the spindle.  Lubed em good and ended up using locktite on one as I recall.
Edited by Rick of HopeIN - 06 Mar 2011 at 8:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 8:30pm
I believe they are supposed to turn in the hub. I also used a spot of locktite to keep them from turning on the spindle, but they are stiff.
