7030 hyd problem
daviem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daviem Quote  Post ReplyReply Direct Link To This Post Topic: 7030 hyd problem
    Posted: 06 Mar 2011 at 8:02pm
My 7030  remote valves does not have any power. They will move small cyls. with little weight  but will not move ones with weight. Every other function  on tractor  works including 3pt. any ideas would be helpful. thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 9:11pm
Both flow controls have vibrated themselves to the slow (turtle) position.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 9:39pm
Could be piolet check in 3pt valve. Remove allen plug ontop of 3pt valve close to where line comes out to lift cylinder. Remove spring and poppit, use straw on pennitrating oil can and spray into hole to clean seat. Replace parts and try again.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote daviem Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2011 at 12:08pm
it was the piolet valve  thank you for the help
