WD-45 Battery
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Battery
    Posted: 05 Mar 2011 at 4:14pm
Question re: battery drain - I put a disconnect on the "positive" cable that goes to the starter in hopes it would correct the problem of having a "dead" battery after a couple of weeks. It didn't help. I will put a disconnect on the ground cable to solve the problem, but why didn't it work?
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 4:21pm
As long as you didn't have any accessory wires connected to the positive terminal of the battery, it should have worked. Breaking the circuit, either positive or negative should solve the problem. It may be a bad cell in the battery. Have you had the battery checked. Even new ones can be bad.
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 4:27pm
Need more info,is it 6v or 12v,positive or negative ground,generator or altinator????
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 4:40pm
Battery is less than 1 yr old.  It's 12V w/ negative ground. I believe it's an alternator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 5:21pm
It doesn't matter if it is 6 or 12 volt, pos or neg ground, genny or alternator. If the only thing connected to the pos post on the battery is your disconnect to the starter, there is no way for anything to drain the battery except an internal problem with the battery. That is as long as you disconnect the battery when not in use and you are not depleting the charge while running the tractor. If you generating system is not working, your battery will discharge every time you run the tractor and will eventually go dead even being disconnected when the tractor isn't running.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 7:24pm
If the top of the battery is wet, that will discharge it too. Keep the battery clean. Not only does keeping it clean prevent rusting the battery box, it also prevents corroding the cables.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 8:10pm
You have a bad battery or no charging system.
This page was generated in 0.104 seconds.
