what is it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Topic: what is it
    Posted: 04 Mar 2011 at 11:28am
 I was going through a box of parts and found this little lever. it is painted AC orange and is a new old stock part. I have no idea what it is or what it goes to. Can anyone ID this part?      Thnaks Matt
Edited by Matt (Jordan,MN) - 04 Mar 2011 at 11:28am
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 1:55pm
If you have a good imagination, it looks kinda like some sort of fish with a hole behind its head
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 2:42pm
Does it have a casting number on it?
ALLIS EXPRESS!
This year:
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:39pm
It's a peice of metal, laying on a PVC pipe, or other tube of some kind??  :o)
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 1:32am
There is no casting numbers on it. I was thinking is a lever for a injection pump? Matt
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 5:33am
It's a conversation thingy and so far it's doing a good job!
Actually, I'm lost for words as to what it really is and am curious myself.
What are some measurements?
Edited by JoeO(CMO) - 05 Mar 2011 at 5:40am
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 11:33am
Matt I believe that might be a part for the pitman on a sickle, like on a bean head or one of the newer sickle mowers. Just an idea.
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 11:38am
Some limited travel control lever, probably inside a console, or beside a panel.  brake lock?
My first thought was knotter part but I've never seen an AC knotter up close.  Not a big help, sorry.
karl f
Edited by kffischer - 05 Mar 2011 at 11:40am
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 11:53am
is it a trip lever for a corn planter for seed fertilizer,etc.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 2:41pm
I'm surprised that no one has correctly identified the part. It was certianly obvious the moment I laid eyes on it' That is one of two (as needed) framistan levers or more correctly mechanicl connecti0on devices for the discombobbulator on the muffler bearing on a Model G Heavy Use tractor!!!!  Darn!guys get it together for once!
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 4:54pm
 Appears to be stock unit...Krptonite or unobtanium type was far more popular. Probably why it was unsold........
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 5:14pm
I thought it was the engagement handle for the Flux Capacitor so you could take your Allis back to the future. If it worked that way, would we still have Orange tractors being built?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:00pm
Beeman and CTucker, I know that was sorta cheap humor on our part, but darnit, ya gotta work with what you have.  I can't think of any thing that I've ever seen that was close to this one. I suspect the ball end was hooked to something that slid back and forth, the hole might have had a shaft through it and the jaws would catch and hold a pin, kinda like the mechanical trip on a plow wheel. Sorry, that's as close as I can come.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 6:43pm
The ball end looks like the rod connection to the choke on an 8N Ford. The big hole might be a pivot point and the small hole for attaching a return spring. I have no clue what the forked end would connect to or operate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 7:00pm
Just does not ring a bell. Matt may be right about  inj. pump control.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 7:28pm
Another thought I had was as a trip lever for a weight device on a thresher or combine for weighing or bagging grain. If a shaft with an eccentric pin revolved in the mouth, it would cause the lever to partly rotate, maybe tripping something. The hole looks as if it has a keyway cut in it for mounting to a shaft. I know this is farfetched, but is as close as I could come. I have never seen the weigh device I'm referring to. I have seen one working at an elevator once, but do not remember how it was built or operated. I remember going to our elevator once and seeing the steam engine and jackshaft and belts that drove the elevator belts and cleaners, but I was probably 5-6 years old and as how I just turned 70 Feb. 4, that was a long time ago!!!
iranch(SESD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iranch(SESD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2011 at 7:58pm
It's a choke lever for an older Stromberg carb.  Possibly off a Ford.
The linkage connects  with the ball on the bottom end,  the top flips the choke butterfly with enough slack for the choke to open a little when engine vacuum comes up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2011 at 12:05pm
I could see that.  It looks very similar to the same type of lever on JD and IH planters I have seen.  The last checkrow stuff is pretty old though, I think it's the newer orange paint, although computers are not accurate with color.
karl f
This page was generated in 0.110 seconds.
