All time top tractor sales by model
MikeB (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Topic: All time top tractor sales by model
    Posted: 03 Mar 2011 at 9:36pm
Trying to compile a list of the top twenty of North American tractor model by sales.
See if you guys can find some I missed.  Probably a million Fordsons made between England and Detroit but this is the number used for North American sales. Acgo claims
Massey Ferguson made more than 350,000 model 135's, but I don't think near that many made it here to North America so I left them off the list for now. I'm just rounding off the actual production numbers.
1. Fordson "F" & "N"    675,000
2. Ford  8N                 524,000
3. Farmall H                391,000
4. John Deere B          300,000
5. Farmall M                297,000
6. John Deere A          260,000
7. McCormick 10-20    219,000
8. Ford-Ferguson 2N   197,000
9. Farmall Cub            186,000
10.John Deere 4020    184,000
11.Allis Chalmers WC   178,000
12.John Deere D         160,000
13.McCormick 15-30    157,000
14.Farmall F-20           154,000
15.Allis Chalmers WD   146,000
16.Case VA                 143,000*
17.Farmall Regular       135,000
18.Ford NAA               129,000
19.Farmall F-12           123,000
20.Allis Chalmers B      123,000
*The Case VA includes all versions of it and the best of that model is the VAC at 95,000 units. The most amazing number in this group is the John Deere 4020 at 184,000 units the only tractor of the group newer than a mid fifties build.
Edited by MikeB (SD) - 04 Mar 2011 at 10:17am
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:38pm
very interesting on the JD 4020...
Great-granfather's WC---- hopefully many more to come!
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:49pm
If it were divided up by the amount made per year rather than total built it may change numbers quite a bit, considering the farmall M was made for a lot longer than say a WD, or WD-45.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 9:55pm
Another interesting note: on yesterdays tractors website there is a poll that had to do with the type of tractor people had when they were growing up, or farmed with, and A-C blew the others out of the water.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 6:29am
Deere numbers on the A and B are wrong. I extensively researched the numbers on the A cause for years Deere claimed exactly 300,000 A's and exactly 300,000 B's. I knew that was BS. The A, and I have the numbers written down somewhere, including all versions of the like Orchard etc is around 260,000 from 1934 to 1952. The Allis comparable to the model A would be the combines numbers of both the WC 1934 to 1948 and the WD 1948 to 1952. I left 1953 WD number off the list to come closer to the same build dates and the WC, WF and WD production was somewhere around 330,000 all together. The only reason Allis wasn't considered the biggest tractor maker was fewer models and their other equipment, save the All-Crop, weren't nearly as entrenched as the long known lines of Deere and McCormick such as seederes, planters, plows etc.
The reason I combine the WD and WC is cause of the time frame match up and the fact that other than hydraulic features there wasn't a lot more different. I would guess there are many more swapable parts from a WC to a WD compared to an early A vs a late A. Of course an M is an M is an M.
Edited by Lonn - 04 Mar 2011 at 6:32am
Wink
I am a Russian Bot
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:10am
Mike, Interesting list and thanks for putting this together. According to Wendel's book, there were at least 127,186 AC B's built, with the final year, 1957 blank and there were probably few that year. If you include the IB's built with their own serial number, add 2372 more (as you included all Case V's). The earliest IB's are included in the B numbers. I say this as I don't want to see the AC B, my favorite, bumped off the top twenty by another. Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeB (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 9:45am
 Bob unfortunately Wendells numbers are wrong as he assumed their were no serial number breaks in Allis B production. Swinfords book clearly identifies a serial number break happening in 1942-1943 time frame with the change to the 3-3/8" bore on the engine. Also Swinford counts the units built in 1957 and actually their were 110 IB's only made in 1958. There were 120,113 total B's built and 2,850 IB's built according to Swinford's records so I will adjust the list to reflect the approximately 123,000 built.
Thanks Bob.
  Lonn thanks for the Deere data, getting acuurate data on them is next to impossible as they would randomly skip serial numbers without logging an official serial number break.
The 4020 data is still a best guess but it is from a Deere insider that worked their at the time. Actually Deere used over 202,000 serial numbers for the 4020 and some one would have to manually look up sales records as these were not logged in a computer at that time. Also Lonn do you have a guestimate on the "B" numbers? I thinks its widely acknowleged that the B outsold the A. I will adjust the list to show these changes.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 11:02am
How many of each are still running? 10 bucks say there is a higher perctange of farmall H's and M's, and Wd's and Wd45's still running than JD A's and B's
Edited by ac45 - 04 Mar 2011 at 11:11am
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 12:17pm
I remember that poll, seems that there was a concerted effort by our forum members to effect "Chicago" style voting, "VOTE EARLY, VOTE OFTEN". We made quite an impression for a couple of weeks until Kim caught on to what we were doing. Sometimes it helps to have members knowledgable about computers, ya'll know who you are! LOL
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 2:39pm
Around where I live its is all old John Deeres and Allis Chalmers and Fords. Many many Farmalls scraped or out in a fence row dead.
I bet I could go out and find a different JD A, AC WD45 and Ford Work master in running condition everyday, they are everywhere here.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 3:42pm
For the Jan/Feb issue, Two Cylinder Magazine counted Deere factory build logs for the new generation tractors. They say there were 129,906 early version 4020, and 55,851 late version. Plus 8095 model 4000 tractors built on the same line and using the same serial number sequence. Total 193,852. The first 4020 was SN 65,000 (continuing with 4010 SNs actually that ended with 59212). The last 4020/4000 was SN 270,288. Serial numbers not used: 90253-90999 115732-118999, 200785-200999, and 242581-249999. 11649 sn skipped. Misses computing by 211 tractors.
Gerald J.
JH Buck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JH Buck Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 5:33pm
Very interesting  Thanks
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 6:14pm
The Massey 135 was the Worlds most produced sold tractor at one time. And a ton of them were sold in North America! Will see if I can find the numbers for them.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:25pm
weren't Fordsons English?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 9:54pm
The reason there was so many 4020, That was the first real modern tractor JD built.  MACK
This page was generated in 0.855 seconds.
