1962 D-15
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 1962 D-15
    Posted: 03 Mar 2011 at 8:15pm
Found one for sale here in Ohio and I know really nothing about them.  This one is a wide front, snap coupler, has been rebuilt, tires ok on rear, new on front, rims are good front & rear, paint is nice original.  The front grill is dented on the top.  Everything seems to work.  They are asking 4800.00 which I thought was a little steep.  Any idea's or comments??  I'll try to get a pic of it posted this weekend.
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:17pm
Larry - were you able to check tranny for jumping-out-of-gear issues?
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:18pm
no, seen on lot and called.  Did not fire up.  What do I need to look for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:25pm
Larry, most of the D series tractors were plagued with under-engineered trannys. As a result, after years of use the tranny would pop out of gear, usually 3rd, sometimes 2nd. Best test is to drive it and check all the gears for this. Sometimes they will stay in gear as long as weight is on the tranny, so check running downhill as well. I THINK that the some of the D15 series (there were several) came with re-engineered tranny that was mostly immune to this problem. Others on here will know better than I!
Also check the Power Director - should snap in nice and tight on both high and low ranges. Beyond that, check the usual stuff (water in oil, ugly noises, power, etc).
WC, CA, D14, WD45
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 10:07pm
To me, $4800 is very high for a Series I.  A few months ago I bought a 66 series II with factory 3 point and full hydraulic AC 400 loader for less than that.  For what you are looking at, I would not go over $3000.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 2:56pm
thanks.  I have no idea what they are worth and I thought that seemed real high to me
