right plow wrong shares
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Topic: right plow wrong shares
    Posted: 03 Mar 2011 at 11:21am
 I got my new plow home wednesday and started cleaning it up. I wanted to find out what bottoms I had and then look for some shares. What I've got is a 63 frame with 363-16 bottoms. I found some shares in Texas and had them send me a picture which made me notice that the shares on the plow now were wrong. I think that 363 bottoms should have 4 bolts not 3. The pictures are the plow now and what I think is the correct share PN 70326086.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 11:49am
if they work..use em, they'll wear out soon enough, then put your right ones on!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 11:57am
That's what I was thinking and if the ones I ordered are wrong I'm sure I can find a buyer on here.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 12:35pm
According to my 7/68 plow bottoms book, the 363 could use a couple different plow shares, which they called "blades." For 16" right hand they were 325552 bullet regular and 326086 bullet, heavy duty. It says 16" bottoms should have four bolts on the shares with three in the frog and one in a strap that bolts to the moldboard. For the 361 to 363 family which came in 12, 14, and 16" widths left hand and right hand, there were only two frogs, left hand and right hand.
I see 4 bolts in the bottom edge of the moldboard and the top edge of the front share in your picture.
Some AC bottoms have nearly a dozen different shares for the same size. Shares came full cut and narrow cut, deep suck, regular suck, alfalfa, soft center steel for rocks, regular steel, chilled iron for long wear. All variations on the same theme for different soil or different user preferences.
Ther may have been a period where the 363 shares were available in as many variations but in recent years most of the variations have been dropped.
Looks like the shares fit the frog and the modlboard and the leading edge is in line with the edge of the shin. That's a fit.
Gerald J.
This page was generated in 0.108 seconds.
