G charge /light switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: G charge /light switch
    Posted: 03 Mar 2011 at 6:46am
OK, in my zest to get my 'new' G running after I rebuilt the generator, I can't find the scrap of paper that had what wires go to which screws on the switch.Arrghh...should never have cleaned up the garage.It deserves all new wiring,cut,cut,snip,snip,ooops...
I have the overall diagram, but nothing like a closeup of the switch with labels as to what the terminals mean.Anyone know what R,H, S really mean ?
Sadley, this is the SECOND time I've done this and can't find the original scribbles I did 4 years ago on my first G.....
Sigh, getting old..what happened to the 'wisom of the age' nonsense ?
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 3:48pm
Jay,
I don't have the answers  you need but am also rebuilding my G and will have the same question in a few weeks.  When you get and answer, please share.
Dick
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 3:59pm
Jay, if I am right, the terminal closest to the front (knob) goes to the Field (F) on the generator.  The connector in the rear goes to the head and tail lights.  If there is a resistor on the switch, its output goes to the Ammeter, If the resistor is external, the middle terminal goes to the resister.  HTH,   Dave
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:01pm
tech pic    Check this link out. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:12pm
Edited by Dave Richards (WV) - 03 Mar 2011 at 4:16pm
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 4:20pm
Does the 6 volt positive ground G wire up the same as a CA with a 6 volt pos. ground system?
Edited by Lance/SC - 03 Mar 2011 at 4:24pm
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:47pm
The diagram does a bad job of showing it, but the wire from the F terminal on the generator is a GROUND, not power.  Mix it up and it wont charge.  My generator got pretty hot too, but I never left it long.  Learn from my mistake Jay.
Also, a good read before you dive in:  http://dueyschutter.freeservers.com/photo5.html
Edited by Roddo - 03 Mar 2011 at 7:53pm
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:43pm
The 6v pos ground wiring on the G and the CA would be the same...
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:53pm
So the light switch has to be grounded I take it. That way it grounds through the resistor for low charge and direct ground for full charge?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 10:00pm
You got it
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 7:37am
Ok, hopefully the picture will help...
Looking at the 'bottom' of the switch, with the knob at 3 o'clock....
bolt at 12 o'clock, going to fuse is 'B'....from ammeter from battery ?
bolt at  1 o'clock, is labelled 'H',goes ?
bolt at  3 o'clock, other side of fuse(to load), tied to bolt at 9 o'clock, goes ?
bolt at  5 o'clock,is labelled 'R',tied to bolt at 6 o'clock,goes ?
bolt at 10 o'clock, is labelled 'S', goes ?
The field wiring is easy, though I need a new resistor(3 ohms, 7 watts),no big deal.
After 'ringing' out the switch I can't find the lights switch contacts,so maybe it's 'burned' out internally.I have another switch  yet to be tested.I know some of the connections weren't used.
Hopefully someone can trace the wires for me,once I get it working right, I'll post pretty picture and tesxt of what goes where.Sure wish I hadn't 'misplaced' my scribbles from the first G....
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2011 at 8:11pm
I can't be much help looking at your picture but the power for the lights should go through the fuse.
RTcat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RTcat Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 6:49am
Jay,
Must be ESP(N) in the air as I was doing the same thing this weekend, trying to get the lights on my G to work!   Using terminals 3 and 9 will have your lights on all the time I found as they have a constant 6 V while running, regardless of what poisition the switch is in.
I inherited my G from my late Grandmother.  It was unmolested and origional as far as I can tell.   I recently had the motor overhauld by the local tracor dealer and had a new wiring harnes installed.  Let me double check, but I think  1:00 is where my front light is hooked up.  However, I have no juice at the light when the knob is pulled half way out.  I'm thinking my origional switch is bad as far as operating the lights are concerned.  The switch however still correctly changes the load on the generator as the tractor rpm's slightly change and the amp needle moves when the swithch is pulled out halfway and all the way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:30am
RTcat, is your fuse burned out?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:35am
When all is said and done, COPY all info and pictures to you computer!!  Put it into an Allis-Chalmers folder and you won't have to be looking for scraps of paper anymore.  LOL  Been There, Done That...and still learning...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 7:46am
All the 6V systems operate the same. On the old Delco Remy round switch itself, the "S" terminal on the switch takes care of the headlights & tail. The other wire that runs off the switch is the grounding terminal (field) which utilizes the extra leg off the resistor. This increases or decreases the ground as you pull the switch out. When the switch is all the way in, your charging circuit runs through the 3 ohm resistor at the bottom of the switch. Pull the switch out to the second position, you by-pass the resistor (increase the ground-full field) and Headlights come on and full charge should occur on the Ammeter. Third position- no Headlights/full charge or full field continues. Just don't leave it out and forget bout' it. You'll boil the battery. The fuse on the tower takes care of the Headlight/tail circuits. Off the minus side of the Ammeter is your Battery feed to the fuse tower. Now, make sure that switch is grounded well in the box. Its a self-grounding switch, and things will not operate without it being grounded correctly. I always tell our customer's to run a little aux. wire off the #10 machine screw that holds the switch in the box to the Pos. ground cable at the Battery. This ensures the switch is grounded, and doesn't just rely on the box for the grounding chores. You should be good to go. If you need a switch, I rebuild them, and have an exchange program on them. I make the internal parts for them also... HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote RTcat Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:47am
It doesn't appear to be burnt out, plus I've got juice coming out of the two terminals connected to the post the fuse is protecting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RTcat Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2011 at 9:53am
Steve,  thanks for the info!  I'm wondering if my light wire is connected to the wrong terminal.  Looking at the picture above, I can't remember from memory which terminal my light wire is connected to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RTcat Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 7:40am
Just want to take a second and let everyone know the quality job "Steve" in New Jersery did on my G light switch.  Switch looks like it just came out of the factory.  Works great also as I now have 6 volts to my light wires.
I also purchased his wire harness kit for my G which I'll install this winter.  Everything is labeled well and individually packaged, with instructions.
Thanks Steve!
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2011 at 8:09am
Thank You Dave! We appreciate the business! Glad we could help! If you have any other electrical questions, be glad to walk you or anyone else through it. I enjoy helping folks out with their wiring whoa's and charging delema's...
Steve@B&B
