WD45 Spindle Bushings
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Spindle Bushings
    Posted: 01 Mar 2011 at 6:38pm
Can anybody get the illustrated parts list for the front axle of a WD45? I need to get spindle bushings and thrust washers. Mine are all wore out. I need to place the steering shaft bushing that goes through the quadrant also. I went to the Agco site and it says you need a passcode to view??? Need to tighten up the steering in the gearbox to. The I&T manual I have isn't that great.
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 8:14pm
Go back to the Agco Parts Book site and where they ask for a password, look to the box below.  Beside Guest User: click on View Books.
Follow this path exactly.  It is sort of illogical:
AGCO Allis/Parts Books/Miscellaneous/Power Units/WD/WD45/WD45D......
Then scroll down to Axle Steering and Wheels.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 9:39pm
Oh ok, didn't see that part the first time. I see there are no prices listed that way they can make you have a heart attack when you go to the dealer and find out, lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 7:01pm
Looking at the manual it seems that replacing the bushings are pretty straight forward, but is it really? I don't know if I got anything laying around big enough to knock the old ones out. Anybody know how much the bushings and thrust washers cost? I can't seem to ever get a hold of the local Agco dealer, guess I gotta make a trip down there.
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2011 at 8:10pm
Blake,
Give B&G Equipment, LLC in Hopkinsville a call @ 270-885-7333. Larry Brannon, Mgr. or Virgil Bishop, parts. Or if you are closer to Paris, TN call B&G Equipment, Inc. @ 731-642-1242. Tim Brannon is the manager, and contributes information on this forum regularly. Kevin Jackson is parts manager, and he can find your parts. Tim can tell you how to fix your tractor. I will assure you your call will be answered at either location.
Lanny   Mid TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 6:05pm
Went to the local dealer today and he said the spindle bushings are $20.23
After I got back home I realized I didn't ask if that was 20.23x4 or if 20.23 was for all 4 bushings. Oh well Ill just have to go back.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 6:30pm
I bought some 3yrs ago, I believe I payed $17 a piece.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 10:24pm
That will be per bushing.   (X4) But they fit.Your spindles are probably necked where they ride.Can be weled up and turned down.
