3-14 or 3-16
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Topic: 3-14 or 3-16
    Posted: 01 Mar 2011 at 8:20am
I'm going to look at a couple plows tonight the guy has a 3-14 and a 3-16. The 14 has bad points that he welded on to get it to suck and the 16 he said is in good shape and was used last fall. The price is basically the same so that's not the concern.  I am wondering if the 16 is too much plow for my 45. The 45 has new tires and one set of weights with a new engine rebuild. I pulled a 2-16 last fall in third with no problem. I guess if I can't pull it I can always sell it and get a 3-14. Thanks, Doug.
WestAllisWD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WestAllisWD45 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 8:26am
We pulled 3-16 trailer plow with our 45 gas.   Medium soils 7-8" deep.   I'm sure a mounted plow would have even been better.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 8:33am
If that 3-16 doesn't work out I'll buy it from you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 10:25am
The 45 is capable of pulling 4-16's when it is new, which obviously it isn't.  If your 45 is in really good shape, it should have NO problem with a 3-16.  Wish I had one, or a 4-14 or 4-16.  I have a 3-14 and I pull with it in 3rd, but I don't have real rich dirt.  Mostly sand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 10:30am
Make him a deal,  buy both !
Can never have enough orange !
The not-so-good one could be next Winter's project .
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 11:21am
You would never pull a 4 bottom plow in this part of Indiana with a WD 45 unless you were in sandy soil. I pulled a 4-16 Oliver 565 with my 190XTD III and it made it bark! Most of those promotional photographs were taken in very light soils!
Chris WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris WI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 11:58am
Go with the 3-16. The WD should handle it, and it will pass trash way better. 14 inch plows  can plug a lot more often and really take the fun out of plowing.
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 2:20pm
I have both 3-14 and 3-16 like the 16 way better!!! My 3-16 are semi mount with hydrolic tail wheel,I can turn trash under better with this set up.My WD45 will pull them in 3rd but I keep it in 2nd,just too stony here...
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:01pm
Doug, I pull both 3-14" and  3-16" plows with my WD45's They will both do a good job if the plow is  not bent of wore out. Come on down when it drys up some and you pull both plows and make up your mind on what plow you like and then go buy one, heck you can buy one of my plows if you don't get a good for this guy. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 9:17am
 I bought the 3-16. It's in great shape everything was greased and free turning with good points, shins and boards for how much?  $150! Now if my wife will let me plow the front yard!
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 9:22am
Congrats on your new plow!
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2011 at 10:31am
I second what Chris Wi said!!
This page was generated in 0.344 seconds.
