CA Narrow Front |
cmsmoke
Joined: 19 Feb 2011 Location: Johnstown, Pa Points: 118 |
Topic: CA Narrow FrontPosted: 02 Mar 2011 at 1:55pm |
Thanks to all. I am sending a PM to Chris shortly. Be forwarned...I'm sure to have more questions later! |
Ken in Texas
Joined: 11 Sep 2009 Location: Henderson, TX Points: 5919 |
Posted: 02 Mar 2011 at 7:31am |
I just checked the part numbers for the pictured narrow front assemblys for a C and a CA. They are the same part numbers in every detail. Go for it
cmsmoke
Posted: 02 Mar 2011 at 6:08am |
Sorry Guys, I was in a hurry and couldn't figure how to get them smaller. I'll work on that for the next time!
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 01 Mar 2011 at 7:04pm |
The picture must be to small. I can't see the fly eggs.
cmsmoke
Posted: 01 Mar 2011 at 5:52pm |
Here is my front. You can see that another axle was welded underneath and the origonal spindle stubs cut off. The wheels have different offsets as well (1 is newer, 1 is origonal). I used a spacer that makes them more alike for temporary. I will get another wheel that matches one of the ones I have shortly. This is not a terrible repair, it has been this way for years, but it is not right and doesn't work in high gear for road travel.The bolts are on 4" centers, as near as I can measure with it together and the length of the pedestal is 11-3/4" with the tape resting on the pedestal. I didn't put a square to it just measured it on the bias.
cmsmoke
Posted: 01 Mar 2011 at 1:07pm |
Thanks, Dakota Dave. I need to check the parts book for the correct terminology (mine is probably off), but it sounds like it will work. I understand the backlash and shimming, since it will go on a different tractor. Good point! Once this is done I'm moving on to the steering box.
cmsmoke
Posted: 01 Mar 2011 at 12:58pm |
Chris, It looks just like yours, I am assuming there is a plug up top on the underside not shown. I just wonder if the bolt circle to mount it and the height are the same. I don't have mine off right now, as I'm using it, but can post a picture of the mess this evening. I will take some measurements of the bolt centers and the length of the pedestal as well.
Thanks Edited by cmsmoke - 01 Mar 2011 at 1:01pm |
Dakota Dave
Posted: 01 Mar 2011 at 12:40pm |
Yes the front support from a CA will bolt to a C front bolster. I have changed them. Check the Spindle top gear you will have to adjust the shims for the correct end play.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 01 Mar 2011 at 12:15pm |
cmsmoke, Can you post a picture of your front end? It may help determine you predicament. Sounds like it should bolt right up [unless your front support is messed up] I cannot remember just how the front support is set-up in a "C".
cmsmoke
Posted: 01 Mar 2011 at 12:10pm |
Dick L, or whoever replies first. Can I just put the part that Chris shows above on my tractor? I won't have the bulkhead that mounts to the engine with the bosses that a "CA" has. The previous owner ruined the spindles on mine, cut them off short, then welded another axle on below, which raises the front about 1-1/2". I am unsure how they oriented it for toe-in, ect. and it is not centered. I believe this has some to do with why my tractor has the violent headshake I asked about previously. Chris has offered me his if it will work.
Chris/CT
Posted: 01 Mar 2011 at 10:54am |
CA NF
Dick L
Posted: 01 Mar 2011 at 10:15am |
Yup.
I put a CA narrow front on my C so I could add weigh in the front.
cmsmoke
Posted: 01 Mar 2011 at 7:14am |
Will a "CA" narrow front fit on a "C". Thanks
