tapping out dents?
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Topic: tapping out dents?
    Posted: 28 Feb 2011 at 9:46pm
when you tap dents out of a hood you dont heat it do you? i dont want to warp anything. do you just go at it as is?? thanks!
Great-granfather's WC---- hopefully many more to come!
acd21man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acd21man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:04pm
i think u can take bags of sand on one side and peck the other side (i may be wrong tho lol)
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:14pm
hmmm interesting.... more i think about it the more i think this is a dumb question... hahaha no heat.... i dont think sometimes...
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 5:55am
Old body shop guys used a tool called a dolly to hold on the other side of what ever they were trying to bump out. That art is all but lost.
Dusty
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:05am
On many occasions I have used a block of wood shaped(usually with the grinder and belt sander)to fit an area, the tapping with the different body hammers and dollies to bring back the surface to where it was, and sometimes, I have been known to take a few 2X's along with BFH and beat the heck out of grills, hoods and fenders (no heat) to get them close before sending to the salvage.  HTH
Edited by JoeO(CMO) - 01 Mar 2011 at 6:09am
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:09am
All depends on how deep the dint is. A small dint you can place the dolly under the dint and tap it back even as long as you don't stretch the metal. For a larger dint the metal has already been stretched so you would off dolly it. that is place the dolly off center of the dint and tap the dint down as you work the dolly around the outside of the dint working out as the dint goes down and the metal thickens back.  Not a wham bam thank you mamm kinda deal.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:32am
Exactally. I was told you have to "ask"the sheet metal to move, not force it.
I have used heat on real deep dents, just have to be careful not to warp it. I usually use a propane torch or the small welding tip on the ox/acy torch.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 6:55am
Like Dick says is how I've been told how to tap dents out. Start at the edges and work your way in. If it's not possible to get the dent all the way out tapping, get as much out as you can and use filler to finish it out.
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 9:56am
I'm taking a night class on body work. Another excellent tool is called the Bull's Eye pick. It's shaped like an overgrown set of ice or log tongs. It allows you to work from the back side while standing in the front and precisely know where the force your applying is. Above comments about offsetting the dolly are correct although when picking out a small dent in the edge of the material you may need to bump directly on the dolly. Heat is used to shrink the metal when stretched by the damage. Doesn't always work and is a bit of an art. On 20-24 gauge material it takes a low flame. Many body experts use a jeweler's torch. Start working the flame in a circle, rather quickly, around the edge of the stretch then bring it into the center leaving it there only until red hot but not molten. Remove the flame and lay a wet rag on the spot. Repeat until you get results or give up and use Bondo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 10:17am
I had a pretty nasty looking dent in the CA hood. I used the SIL's cheap hammer and dolly set to work it out. I put the dolly under the dent and hammered on the dented side around the edges. It seemed wrong to start with but after taking a good amount of time and just tapping away, the dent is gone and the hood looks really good again.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 12:05pm
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 8:15pm
have any of you gurus ever used dry ice to remove dents on sheet metal.how does it work?i have seen it but did not pay attention...
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 9:22pm
 I HAVE USED A HEAT GUN OR THE HOT JULY SUN TO PREHEAT A DENT AND THEN DRY ICE . SOME DENTS POP OUT NICE AND SOME NOT AT ALL. LOTS OF HAMMER AND DOLLY WORK---TAKES TIME, BUT WORKS GOOD.  I ALSO DON'T USE BONDO MUCH , I HAVE BEEN LEADING TO FFINISH THE REPAIR.
WD,D17-S4,180,D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 10:59pm
will the really little ones sand out with the sandable primer?? or does it need to be pretty much smooth to start with?
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 11:01pm
It takes alot of primer and sanding to get any kind of a dent out your best bet is to use a little body filler or some glazing putty.
Just my opinion,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2011 at 11:15pm
alright. would you recommend a hard plastic squigee or a rubber one?
This page was generated in 0.582 seconds.
