53 CA starting issues...
53allisca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 53allisca Quote  Post ReplyReply Direct Link To This Post Topic: 53 CA starting issues...
    Posted: 27 Feb 2011 at 4:51pm
Hello,  Needing some help...  My 53 ca will not start,  not even with a jump.   Is there more than one fuse on this machine.  I found the one that is in the ammeter box and it is not blown.   All battery cables appear to be tight and clean.  The starter would at least attempt to roll over or click with low battery,  but will not even do anything even with quick jump from charged 12v battery.    What could i be missing??  Thanks in advance for you suggestions.
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 5:15pm
I would suggest tracing the starter circuit and carefully check each connection.  I can post a wiring diagram if you need one.  Especially check your ground and contacts inside the switch (on top of the starter).  I bet you will find a corroded or rusty connection somewhere.
  I am assuming that you have checked the battery with a voltmeter and it shows in excess of six volts.
  I am not sure what you mean about "more than one fuse".  It sounds like there may have been some modifications over the years.  The only thing I can think of on a 53 CA in the ammeter box that would look like a fuse would be the resister for lights/charging system.
  Next I would remove the starter and clean where the starter nose cone meets the "bell housing".  Clean the starter bolt too.  Normally I recommend checking to make sure you have heavy 0 or 00 battery cables, but it sounds like it has worked in the past.
  Six volt systems require much more amperage than 12 volt systems.  Amps are carried through good, clean connections and heavy gage wire.  I usually use water as an analogy: You can get water out of a both a drinking straw and a fire hose, so just because you may read 6 volts on a voltmeter (you have water), the connection may not carry the necessary amps to spin everything (you don't have the necessary flow).
   Good luck!  Ryan
Edited by RyanTN - 27 Feb 2011 at 5:17pm
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 5:30pm
Hook the hot side of the 12 volt battery to the starter post. Then touch the neg. side of a jumper wire to the starter body. That ought to tell ya if the starter is working or not. Unhook the tractor battery first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 53allisca Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 5:34pm
Thanks for the advice Ryan,  thats where i will start.  With the starter.   The connections are old,  but just had been gone over by a mechanic friend this past summer.  I didnt even think of the switch on the starter itself.   i will let you know what i find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 6:15pm
Ryan, If you don't have fuse on your light switch, yours is the one that is altered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 6:24pm
Yeah either that or, more likely, my memory isn't as good as I like to think it is!  LOL-- A quick look does in fact reveal a fuse on the light switch, sorry that I wrong/remembered incorrectly.
Of course, this should have no bearing on his starting issue, and I cannot think of multiple fuses in the B/C/CA wiring diagram.  I stand corrected, thanks Charlie.
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 6:32pm
 I had a dead cell on a 6 volt battery and even with the quick start she would not roll . new Battery did the job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:27pm
53CA, either the switch on the starter is bad or you don't have a good connection somewhere. Connections include the contact points of the starter to the block. Sometimes people paint a tractor in pieces and get paint on things that don't need it, like the starter where it contacts the housing.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:50pm
Will it start with the hand crank?
ALLIS EXPRESS!
This year:
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 8:22pm
Hmmm - any chance that the starter is jammed in the ring gear? I'd do as suggested above and pull the starter. While you have it out, test it with cables from a known good battery. If it turns over smartly, then work through the starting circuit. There's very little involved in spinning the engine with the starter: battery, cables, starter switch and starter. You can change out the battery; clean/tighten the cables; jump over the switch; test starter as above. Good luck!
WC, CA, D14, WD45
This page was generated in 0.305 seconds.
