WD45 Hydraulics
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Hydraulics
    Posted: 26 Feb 2011 at 10:04pm
I have the hydraulics on my WD45 set to the "hold" position for using a 3pt mower. I went to the neighbors house today to use his pick up disk, I hooked it up and it wouldn't raise it, do I need to set the system different to operate the ram on the disk?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 6:27am
Before you start adjusting the hydraulic system tell us about the disk, first what size is the disk and are you using a one way ram to lift it? Don
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:37am
Check fluid level.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 8:13am
On the 45, I have never made any changes when using the ram vs. the snap couple rams.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 9:31am
I think it is an 8ft disk. The ram is single acting. The guy uses it behind his D14 and D17 no problems. I checked fluid level and it was good. I use the 3pt all the time it works great, lifts up a snap coupler 3pt AC disk no problem. Don't understand why it won't run the cylinder.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 9:39am
make sure that you have compatible ends on the tractor and the disc's hydraulic hose.
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 10:37am
Check drawing on side of battery box. Lock the two plates together on top of the pump
and the is a screw on the side of the pump between pump wall and hand clutch wall
believe turn this screw all the way out.
Is the hyd fluid to the top level on the gauge stick.
Years ago - late 50's running a horn loader on a WD the hyd tank had to be very full to make the loader go to the max height.
Good luck.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:09pm
I think Chris may have the solution.  Orig hyd coupling on AC was Bruning.  Later when to Pioneer.  They will hookup but won't work.  I believe the Bruning has a ball tip and the pioneer has a pointed tip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 5:30pm
Ahhhhh ok that figures. I have the original male coupler with the extra piece that clips on to make it female. The disk has pioneer I think.
This page was generated in 0.219 seconds.
