D-17 Hydraulic pump
Deer hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deer hunter Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Hydraulic pump
    Posted: 26 Feb 2011 at 1:54pm
Will a D17 seriesII and a seriesIII hydraulic pump Interchange?
Thanks to all that respond
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 5:11pm
Should work, but I'd fix my own and not buy someone else's potential problem.
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 6:53am
whats wrong with your old one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Deer hunter Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 8:12am
The Series II is stuck in the up position with lots of preasure on it.
No matter what position the lift lever or traction boost lever is in.
The pump has seemed weak and sounds like it was only pumping with two pistons for quit some time and was noisy and slow.
This page was generated in 0.355 seconds.
