Hand starting |
TaterHill
Topic: Hand startingPosted: 26 Feb 2011 at 7:35am |
I need some tips on starting my B with a hand crank.My flywheel is in need of replacement so I can't use the starter. Also does anyone know where I can buy a new Flywheel. I have phoned and e-mailed OK Tractor and have not heard back from them.
MNLonnie
Joined: 11 Sep 2009 Location: Baxter MN Points: 4812 |
Posted: 26 Feb 2011 at 8:14am |
Not sure what you need exactly but my experience is all tractors are a little different as far as choke setting, trial and error will tell you what to do. My 1934 WC you choke it and it will be 4-5 cranks, the other WC and M crawler are 1 crank on choke and then usually 1 crank off choke. Other than that put the crank in place so it engages the crank pulley and is at 9:00 position, give it a solid pull up to 12:00 with an open hand(don't grab it with your thumb rapped around it like a hammer). Your not trying to spin the motor just take thru 1 compression cycle. Hope this helps.
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 26 Feb 2011 at 8:47am |
yep quick quarter turns from about 9 - 12 is how I start them and safest way I have found, DO NOT spin the motor if you reach a high enough rpm the magneto will think the engine is running and the impulse will stop tripping and advance timing to running postion which could cause it to kick back.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
pumpkin man
Posted: 26 Feb 2011 at 10:16am |
When my dad bought our first [ B] a 1939 in 52 he showed me how to crank it - dont spin it - hold your thumb back- give it 1/4 turns worked for 8 ys. Wham july 1 1960 it got me the mag. had came louse[found it after 3week s in hospt.] broke my wrist in 3 places then 10 weeks in a cast . then one day reading the [OWENERS MANUAL ] it tells you how CRANK START a B --stand to left side of tractor hold crank in left hand give 1/4 turns. it works if it backs up on you crank pulls out of your fingers. hints on starting open throtle 2 or 3 notchs - be shure kill or eign. swtch is on - if it floods turn gas valve off or start with gas off . your post says you need a flywheel ? shure sounds like all you need is a $ 35.00 ring gear
Jacob (WI,ND)
Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1249 |
Posted: 26 Feb 2011 at 10:40am |
Here is a video of me starting my WD Wayne after getting him and going through the fuel system. He should (and eventually will) start much better than this. Shouldn't take this many cranks.
I don't know if this is the best way to crank a tractor, but seems OK to me. To me the 9 to 12 seems awkward, pulling up seems better to me, but maybe I'm not understanding things correctly. Note I DO NOT have my thumb around the crank, but to the side. Like others have said, don't try to spin the engine over, it won't do any good. [TUBE]4rPkYRPFVPM[/TUBE] Maybe because I'm right handed, cranking this way with my right hand feels more natural? Cranking with the left hand just seems strange. I'll have to try it that way next time I'm home...
Edited by Jacob (WI,ND) - 26 Feb 2011 at 10:46am |
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
JohnCinMd
Joined: 11 Sep 2009 Location: Westminster, Md Points: 1442 |
Posted: 26 Feb 2011 at 11:08am |
Wow Jacob, after watching you try to crank that WD, I need a nap! ;-)
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 26 Feb 2011 at 11:18am |
Jacob - I agree that is the correct to handcrank. Having said that, you need to give that WD a "Tune-up". Your mag maybe weak, or you might have intake manifold leaks and your carb may need attention. You should get it to fire on about 4-5 cranks.
Jacob (WI,ND)
Posted: 26 Feb 2011 at 11:45am |
Oh, I KNOW it needed help, LOL! This was when I just got it and basically just getting it to run after not running in some time (the fuel system was all gummed up). The carb did (and still does) need some TLC. I only cleaned it, not rebuilt it at this vid. And the manifold seals were shot. They have since been fixed and are waiting for warm weather to button things up again. (had the head off for a freshed up, but not a complete re machine) I believe the mag is fine, seems to have a nice strong spark. It WILL start better once I'm done, otherwise I'll tear it apart and fix some more tings until it does, LOL! Thanks for the advice though.
Jacob Swanson
Don(MI)
Joined: 15 Sep 2009 Location: Michigan Points: 3927 |
Posted: 26 Feb 2011 at 11:46am |
Haven't had her kick back yet, I will try the left side thing next time though. I don't know why, but I can't get the dang youtube video to embed in the post. Whats the trick?
Darrell, Jr. (MN)
Joined: 11 Sep 2009 Location: Arlington, MN Points: 234 |
Posted: 26 Feb 2011 at 11:59am |
Everyone has given you good advice, but no one has asked if you have a distributor or a magneto? All the starting instructions given are for a mag set up, and if you have a dist. you will need to be very careful because they will kickback almost every time.
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 26 Feb 2011 at 12:01pm |
Don, copy the URL from youtube then click on the "insert movie " icon. Paste the URL[TUBE]xDbOfZmoaqw[/TUBE] in the youtube box and post it.
Don(MI)
Posted: 26 Feb 2011 at 12:06pm |
SteveC(NS)
Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |
Posted: 26 Feb 2011 at 2:07pm |
Taterhill, did you pick up on Pumpkin man's advice that it may just be a $35.00 ring gear? I've got even more hope for ya. My $35 ring gear is still on the shelf because I swaped starters with my CA and it engaged nearly every time. I took the B starter to a local garage that specializes in gen., alt. & starters to see if they could order me a bendix, they said they could and offered to install it on my starter. The price was good and now the ring gear will wait til I do a full o'haul on the B.
I don't hand crank NOTHIN' , I'm too old and like my wrist just the way it is.☺
Steve M C/IL
Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Posted: 26 Feb 2011 at 9:25pm |
Back'n the day.....when I used my UC,after it was warmed up good from running,you could just slowly lift from 9 o'clock and when the impulse clicked...it was running.Dad talked about starting model T's buy having the engine stopped in the "right" spot and then pulling the spark advance lever to fire the mag. |
farmer0_1
Joined: 06 Dec 2009 Location: cornelius or Points: 592 |
Posted: 27 Feb 2011 at 12:54am |
had a good friend give me the steps to start my ac allcrop engine. turn on gas for fifteen seconds then turn back off at the tank. set choke to choke. pull crank like described speed is not much issue. turn choke off after two cranks . then pull to start , when it starts turn fuel back on. usually will start third pull since i went thru the mag. , carb, fuel tank, plugs wired and cap. and fresh fuel. wish is had a button.
swit
Posted: 27 Feb 2011 at 5:46am |
my B full choke most of the time 1to3 turns and its a running the only reason i rebuild my starter is i had shoulder surgery and i new snow would be here before i was ready to be cranking on it
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 27 Feb 2011 at 8:21am |
I can tell alot of people would have trouble cranking a old big block .LOL
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3979 |
Posted: 27 Feb 2011 at 11:03am |
Most of my old iron is hand crank and most will usually fire off after a 1/4 pull (9 to 12) with choke on and a second pull over with choke off. Even the big blocks, Fred!! Proper timing and tuning is the key.
