shifter problems/7580
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: shifter problems/7580
    Posted: 25 Feb 2011 at 9:17pm
Was using my 7580 to pull the haywagon today haling big round bales. Something in the "T" handle shifter let loose, and now the twisting action doesn't  work any more. It still twists, but just doesn't accomplish anything; it's stuck in the 1st/reverse slot. Any one know if I should start by tearing apart the shifting console first, or take up the floor board? It was a long drive home in 1st gear! Thanks in advance, Darrel
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 11:02pm
theres a cable in the console that could have broken.  Pull the side cover off of the console and you should see what happened.  how far of a ride did you have back home??
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 8:57am
about 5 miles
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 9:12am
Sound like the end of the cable broke, on some models they had a ball stud, that would break also, not sure which yours has, fairly simple fix, just got to get to it.  It it was hard twisting or shifting, while you are there take the time to replace both cables.  If the cable are old and stiff or full of dirt, you will be amazed at the difference!
Still in use:
This page was generated in 0.320 seconds.
