190 owners
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: 190 owners
    Posted: 25 Feb 2011 at 4:57pm
What kind of oil goes in transmission, I think 9gal capacity total , oil supply to transmission, torquehousing , rearend, pto all the same oil
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 5:12pm
beleive allis oil would of been 821, i use JD hydralic oil i all my tractors
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 7:57pm
rear end is 80-90 all other is hyd fluid, agco, JD or CIH brands seem ok from what people tell me.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 10:41pm
Only the final drives on a 190 take 80w-90. The rear end and transmission takes 821 hyd. oil 0r equivalent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 7:37pm
Where do I refill final drives, I see drain plugs , so I can drain, also I drained and filled pto-torquehousing-tranny, It wasnt good fair amount of water in oil , so i should probably drain rearend too and that takes HYD oil also, iwill rearend drain completely?And final drives take 80-90.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 8:08pm
is there somewhere where water leaks inthe tranny and rearend  that has been aproblem for others
1959 D 17 gas , 1964 190 gas, 1965 190xt gas AC 4bottom slat plow, 6 row 30in #72 planter Im not getting bigger my cloths are just getting smaller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 8:19pm
Yeah, there's a flat rubber seal on the gearshifter bell that's probably gone and the metal platform cover that actually covers the shifter with the missing rubber seal is probably missing too. Keep it in a shed out of the rain works good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 10:13pm
I will look at that tommorrow, it would be a cheap fix compared to new fluid every year. I try to keep tractors in shed  as much as possible.  Anybody have a pic of how governor and carb is  connected together.
ironac View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ironac Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 11:42pm
i just use harvest king universal hyd/tranny fluid. i have a loader on mine. works great
This page was generated in 0.299 seconds.
