What am I ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: What am I ?
    Posted: 24 Feb 2011 at 9:30am
uploads/351/pulldiscp1.jpg
Ok, I know it's a pull disc and orange.
All discs are perfect, no wear,no dings,dents, etc. rear bearing never used.
I figure someone here knows the model number and what it's worth if special.
Thanks
Jay
ps. HOW do I get the picture to automatically open in this message ?
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 9:34am
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 12:42pm
looks like the front half of a 6' tandem Allis disc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 1:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 2:00pm
Ok ...HOW did you put my picture up in the message ????
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 5:11pm
Jay, I clicked on your link and the picture shows up. I copy the URL and paste it in this box with a set of brackets [ ]on either side of the letters  img at the beginning and another set of brackets behind with   /img   inside the brackets .  Since you are uploading the picture, you should be able do it like this.
Posting Pictures
To post a picture from your computer, first click on  new topic + or post reply/ . Do not use the quick reply box at the bottom of a previously posted topic. At the top of the box that opens is a row of icons. In the middle of that row is a picture of a tree, click on it. A window that says image properties will open, if that window is small, maximize it so you can see everything in the window. Click browse and find the picture on your computer and open it. Click upload and a small window will open asking you to be patient, click OK in the small window. The picture will appear in the box on the lower right side(if not click preview). Check the width and height of the picture. If the numbers are greater than 800 wide and 600 high, the picture will not be seen completely on the forum. You can change these numbers but need to keep the ratio the same between them or the picture will be stretched. Click OK at the bottom and the picture will appear in your post. You can add text to the post before or after uploading the picture. It is easier to insert your text first. Now click post reply or post new topic and you are done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 5:40pm
Ok...here goes a try of the second picture of my unknown disc...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 5:42pm
Well that seemed to work...don't know why #1 didn't work but then again....it's a computer !!!
Thanks
Jay
This page was generated in 0.555 seconds.
