wd shifter problem
Jeremy(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Topic: wd shifter problem
    Posted: 23 Feb 2011 at 6:50pm
just bought a wd tractor got stuck in gear, now it is in reverse, but my shifter is not free the 1st and 2nd rod will not move in or out and the reverse rod the ball bearing keeps popping out of the hole any suggestions
kip in cny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kip in cny Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 9:36pm
Welcome to the form.  Where abouts in NY are ya ?  I would pull the rubber boot off and remove the snap-ring and all and remove the shift lever. Then you should need is a long screw driver and be able to center your gears into place if that dont work your going to have to pull the shift tower.
160 CA 920diesel 5020 HD-3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 9:52am
waterloo, and thank you for the help i got it all back together up and running
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 11:47am
Your not far from me.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 12:57pm
Must know Don M. from Waterloo???
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 2:03pm
  The ball on the bottom of the gear shift leaver wears and causes a problem like this. I build it up with weld and grind it to shape.
Don Jr NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 6:12am
Hi Jeremy, I'm also from Waterloo. Where exactly do you live? Send me a private message if you don't want to post that info here. Would like to talk to you sometime.  Don Jr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 8:16am
Don did you go look at the combine I told you about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 9:26am
todd this is the tractor i got from u only problem i have had with very pleased
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 1:32pm
What can I do to help you with it???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 5:20pm
todd all set with it, all up and running just a case of operator error think i shifted too quick no problems now thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 7:51pm
Ok. Great to hear!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 9:27am
ok stupid question here serial number of wd11198 that would be a 1948 am i right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 9:45am
According to my book, 'A Guide to Allis-Chalmers Farm Tractors' by Norm Swinford, it is a 49.  48 (7-9249)  49 (9250-35444)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 9:58am
ok thank you
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2011 at 9:22pm
if the shifter ball is worn out,call dean ag and spend 82.00 dollars for a new one
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 7:16pm
got another question my hand shifter wont stay back while in gear it works fine just dosent stay locked in was wondering if it supposed to
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 8:00pm
It's supposed to have a detent ball on the shift rail to hold it.If you don't feel it,it's probably been apart and got left out.Gotta take the whole top off to get to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 3:32pm
whole top off what the shifter housing or the cover under battery tray
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 3:53pm
Shifter top, the cover under the battery is for access to the hand clutch pack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2011 at 9:26pm
Are you talking the hand clutch Jermery??
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 6:09am
Jeremy,
  If your hand clutch is not staying engaged take the cover off of the hand clutch  under the battery box and take out enough shims to give the clutch enough snap to hold it in and so the hand clutch doesn't slip. There is a certain number of pounds pull to get it over center when you pull back on the hand clutch lever(about 15lbs or more), but I can't remember how much it is. To tell which clutch is sliping, if the wheels and pto stop it is the foot clutch. If the wheels stop and the pto keeps turning it is the hand clutch.
If it is the gear shift leaver not staying in gear then the detent spring is broken or the spring and ball is missing for that shifting fork. To repair it you have to take the cover off of the transmission which is under the gear shift leaver. The shifting forks will be there on top where the ball of the gear shift lever fits into them.
Hope this helps
Edited by nella(Pa) - 16 Mar 2011 at 6:36am
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 9:05am
 I have thought about doing this. What is the correct size to build it up to? Or do you just grind it down untill it fits?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 9:36am
When I build up mine I just guess at the size without making it too large. I try to build up the aera that has worn off. Someone on the old board posted the dimensions of the ball but I can't find it, maybe someone else can find it.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 10:15am
The Ball on the end of the shifter should be 1/2 inch diameter and flat on both sides 3/8 inch wide. The hand clutch should be shimmed to 35 thousands of an inch when released. I can't find the drawings I had when I did mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeremy(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 3:40pm
it is the hand clutch i am talking about the shifter stays in just fine the hand clutch lever just doesnt stay back
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 7:49pm
need to check your shim pak.if they are all gone ,time to get new clutch facings for the hand clutch...
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2011 at 7:53pm
i adjust the hand clutch to where there is a positive snap when it is pushed forward.keep adjusting the shims till this happens...
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2011 at 1:52pm
We always used the method that Dakota Dave suggested. Follow the manual and it will work fine.
