ring & pinion swap
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: ring & pinion swap
    Posted: 23 Feb 2011 at 2:29pm
i have a wd45 with a 13:43 ring/pinion combo and i was wondering could i swap in a ring/pinion combo 7:32 out of a wc???? i know a combo out of a wd45 diesel or a d17 would fit and it would be 9:35 which would be 9% slower. better yet if i could find a combo out of a RC at 5:33 which is suppose to be 30% then a WC. so is it worth the effort to swap for a wc to a wd45 ??
thanks rob
if farming was easy everybody would be doing it
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 2:38pm
I don't think it will work. Or someone would have already done it. I think I read on here once that the wc finaldrives and the wd wd45 ones have a different ratio as well. I think the steepest gearing is a wd45d rear end. a wc highcrop or with rc gears is very close. Unless you put in a shurman underdrive in a wc-rc greared tractor.
Allis orange blooded by family. Allis Diehard by choice
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 5:14pm
You can't put a WC or RC ring & pinion in a WD45 or vice versa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 9:17pm
ok thanks for the info... how hard is it to swap out between the wd45 and early d17?
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 11:58am
put a wc tranny in place of the hand clutch housing then u have a 8 speed
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 8:59pm
i  highly doubt that would work
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 9:28pm
WD45 diesel ring&pinion is the same as any older D17 R&P and will fit any WD45 rearend case and slow all gear speeds down about 15%.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 9:53pm
OK, who posted the pic just recently of the WD with a WC tranny in front of the WD tranny?
This page was generated in 0.328 seconds.
