head gasket question
rbaggett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Topic: head gasket question
    Posted: 23 Feb 2011 at 12:31am
When changing a head gasket is it necessary to send the head off and have it checked for cracks or warps or will a new head gasket usually fix the problem.  If you did have a crack would it be visible to the naked eye.  I had water pumping out around the exhaust manifold on the number three cylinder so I wondered if it could just be the head gasket.  Wasn't too bad because I wasn't loosing a noticeable amount of coolant and there is no evidence of water in the crankcase.
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 4:36am
you can check for warpage yourself and look for cracks but a big cause of leaky head gaskets is low liner protrusions. depends on what engine it is whether it is easily repaired or not.
woodbutch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodbutch Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 8:08pm
dad: you said low liner protrusion. Does that cause oil in coolant? how do you get liner to correct position? Do you need head gasket replaced to fix? Didn't mean to jack thread,but seem to have similar problems with hd6
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 4:42am
low liners do not cause oil in the coolant, they just cause head gasket leaks. the liners need to be several thousandths higher than the block deck so the head and gasket can keep them down and in place so they do not move up and down and cause cracks. the liners need to be shimmed underneath the top ring before they are installed. bad head gasket with low liners means they need to come out, check for cracks and reinstalled with shims. oil in water usually comes from a bad oil cooler leaking pressurized oil into the lower pressurized coolant system. oil will pass through a crack also but not as common. what type of engine? buda or allis?
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 5:37am
Which engine is it?
"Burgie"
This page was generated in 0.369 seconds.
