My 190XT III questions continued
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: My 190XT III questions continued
    Posted: 22 Feb 2011 at 7:17am
I am going to hike back up the mountain to look over my new purchase again this morning...how do I tell if it has the flip PTO for both speeds or just 540?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 7:27am
Look at the PTO shaft. If it has more than three bolts around the seal housing it is the 540/1000 set up. If there are only three bolts then it's either just a 540 or just 1000. Does it have the manual PTO engagement or the hydraulic engagement? The hydraulic PTO would have the lever on the side (of) the right hand console a little lower than your seat.
Edited by Lonn - 23 Feb 2011 at 5:43am
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:11am
I hiked back up and took another 60 pics of my new to me XT III. lol This is the PTO so I am guessing from what was said this may have the 1000 rpm also rear? Thanks! Dana
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:16am
Hey do y'all think she needs a new seat?
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:28am
Just put a old pillow in a burlap or seed corn sack for the cushion sause the back rest is still good so I would finish wearing it out before replacng....lol
If fishing is a sport your looking at an athlete
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 12:11pm
nice, Hydraulic 2 speed pto!
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 12:13pm
Yes Captain, it has the 540/1000 PTO option. It's getting to be a better deal all the time. Let's see a picture of the 3 point hitch.
Lanny -  Middle TN
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 2:46pm
Captain, you've found the tractor I've been looking for! To change er over to 1000 PTO, remove the 4 bolts, pull the shaft out and you should find a 1000 RPM shaft stuck into the tractor houseing on the other end of the 540 Side. Flip it around so the  540 side is in and the 1000  side out, and put the bolts back in, only on the inner bolt holes this time. DO NOT HAVE SOME BOLTS IN THE INNER HOLES AND SOME ON THE OUTER HOLES!!!!!!! I've heard of someone doing this, and its not a pretty sight. In a nutshell, for 1000 RPM-all bolts in inner circle, for 540-all bolts in outer circle. It's pretty straight forward once you see how it works.  Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 6:34pm
Hey y'all here's a shot of the backside! Dana
This page was generated in 0.703 seconds.
