D17 lift arms
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: D17 lift arms
    Posted: 21 Feb 2011 at 6:02pm
After reading CORY's post on lift arms, how do you know if they have been moved up or down? My CA will lift my 160 mower higher than my D17 will.  My D17 did have a 3pt on it that used the original arms.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 11:42am
According to the D-17 manual, there is a punch mark on one of the splines on the shaft which is to be lined up so that the lift arm centerline  is directly off that spline.
HTH
