1st Grader
Lou View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lou Quote  Post ReplyReply Direct Link To This Post Topic: 1st Grader
    Posted: 21 Feb 2011 at 8:33am
Hi,
Wondered if anyone could help I have just brought a  grader its either a D or DD
it is yellow at present but closer inspection shows it was originally allis chalmers red.
The engine which has spat a rod out of the block and  is not original  it is a L4 perkins Diesel
with a modified sump , flywheel and fuel tank to make it fit.
the serial No is 00982 or 10982 difficult to see. are there any other ways of checkin the model?
It has a tubular frnt end with a hydraulic ram on the front axle?
If anyone could help it would be greatly appreciated!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 5:49pm
The D would have been gas and the DD would have been diesel but the serial # doesn't make sense. D's were from 1 thru 6300 + or - and DD's were 1000 thru 3000 + or -.
derekhopkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote derekhopkins Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 8:59pm
Hi Lou
I am also in West Aussie.  It would help if you posted a photo of your machine.
Lou View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lou Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 8:02am
Thanks for your reply MN & Dereck,
The reason I am having trouble is that Because the Donk is not original and the serial#
plate is slightly damaged, so it could have been gas or diesel and had a early mod to fit the L4 which looks about the time it was re-sprayed yellow.
The serial # looks like 00982 but the first digit has a vertical dent through the middle.
I will try to get a few pics online later.
Lou View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lou Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 9:07am
Hope these are ok?   having trouble downloading pictures on to this site!?
Edited by Lou - 23 Feb 2011 at 9:16am
This page was generated in 0.230 seconds.
