D-14 Traction
HillbillyJim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HillbillyJim Quote  Post ReplyReply Direct Link To This Post Topic: D-14 Traction
    Posted: 21 Feb 2011 at 7:44am
Is there any way to improve traction with a D-14. Recently we had snow and I was attempting to plow out the drive. The Allis had trouble just pulling itself up a sight incline and when I dropped the blade, it would just set and spin one wheel. I had a WD before I bought the D-14 and it pulled like a champ.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:49am
Tire chains.
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:16am
Weight on the drive wheels (weights, loaded tires) and chains are critical for 2WD tractors in snow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:43am
Fluid in the tires makes a great difference. Some people won't use Calcium Chloride because it will rust the rims. It will only rust rims if it gets on them from a leak and isn't washed off. Most tractors with rusted rims have had fluid in them for 40 or more years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HillbillyJim Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:41am
I am sure that is part of the problem as there is no fluid in the tires. The original owner had the wheels rust out around the valve stems and replaced the wheels with the wheels off an Allis combine and never put fluid back in them. I was just surprised that the D-14 didn't get better traction as the WD I had didn't have fluid in the tires either and traction was never a problem with it. Other than that, the D-14 is a major improvement over the WD as the D-14 has power steering. I was going to put power steering on the WD but the only power steering units I could find were selling for as much as I originally paid for the tractor. I guess I am luck we don't get much snow here in southern Missouri. Will be using the D-14 for brush hogging soon (smile). Thanks for the input.
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:06pm
You can have Rim Guard put in your tires, a calicum substitute.  It is actually beet juice and has a similiar weight to gallon ratio.
This page was generated in 0.132 seconds.
