D14 power steering wheels |
Steve(SEMN)
Joined: 12 Sep 2009 Location: Rochester, MN Points: 836 |
Topic: D14 power steering wheelsPosted: 20 Feb 2011 at 4:22pm |
I have a 1958 d14 that did not have factory power steering. I added power steering to it and was wondering if a factory power steering wheel (the one with the emblem) would fit. Are there other models that would work too.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25239 |
Posted: 20 Feb 2011 at 5:02pm |
Hmm... both my non-power steering D-14s have a cast A-C emblem on the wheel, held in by two screws at 9 and 3 o'clock.
Do the p-s units have a special emblem ?
DrAllis
Posted: 20 Feb 2011 at 5:18pm |
The early steering wheels fit just like a WD45....round 7/8" diameter shaft with a solid pin driven in thru the hub to hold it. The later steering wheels with the diamond shaped cover had a threaded/splined shaft to retain the steering wheel. If you changed the shaft you could upgrade the steer wheel.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 20 Feb 2011 at 7:59pm |
The black bar grill tractors with the splined steering wheel had a diamond logo in the center that said POWER STEERING if so equiped and the A-C diamond logo with regular steering.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7638 |
Posted: 20 Feb 2011 at 11:40pm |
Jay, here is the emblem. As DrAllis and Calvin mention, the 1959 has a different steering wheel that is splined. Earlier ones had a pin that held the wheel to the shaft.
