Sediment bowl shut-off
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: Sediment bowl shut-off
    Posted: 20 Feb 2011 at 3:02pm
My CA's sediment bowl is leaking at the shut-off valve.  Does anyone sell just that valve as a replacement?  Or is a complete sed. bowl assembly my best bet?
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 3:08pm
My D17 Series III is going the same.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
RSponenberg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 4:35pm
Did you try tighting the packing nut on the stem????
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 4:59pm
Give your old tractor a nice present, buy and replace the complete assembly. Both you and she will be happy !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:01pm
Yeah, I tried the packing nut.
I can do a new assy., unfortunately it's like brand new as-is.
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:36pm
Sad to say, I bought one at TSC last summer and it leaks when shut off, but not when it is on.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:38pm
I also tightened my packing nut but I can tell you that won't last long.  Is the packing replaceable?  If so where do you get it?  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:42pm
I have been unable to get a new one in the past few years that did not start leaking at the shut off stem within a few months with one exception. Early last summer I bought one at NAPA and put on my B. So far it is still holding after 10 months which is much better than I was doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:44pm
The one on my 45 started leaking about 5 years ago. I just snug the packing up till it makes the valve turn a little stiff. I think I have tightened it 3 or 4 times in the last 5 years. I would think you could buy packing material somewhere but I don't know what the packing is made of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:53pm
Bought one several years ago from Tony at Tonys Tractors for my B. No leaks as of this past Friday. You can use leather for the packing if needed. My Dad kept several old boots around and used them for packing and gasket materiel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RSponenberg Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:59pm
I wont buy anything from TSC ( tractor supply ) all china junk!!!!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 6:04pm
Same as the last two I got there. I gave up on them and started watchin for originals on Ebay. cleaned them and lap the seats and a new gasket, good asnew.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 7:06pm
Graphited packing string should be in the plumbing department of good hardware stores.
Gerald J.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 7:23pm
I wrapped teflon tape on the stem and then re-snugged the nut.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 7:23pm
back the nut all the way off and roll a rubber O ring over the female side and reassemble I have had to do this a few times
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:37am
Thanks guys.  So I guess that's a 'No' to buying a new shut-off only.  I'll look into some of the options you mentioned.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:01am
RSponenberg, If you see a new one that is not an import, let us know!
We sell complete units for $21 I think.  I run them, and have maybe tightened the packing a time or two in the 6 or 7 years since I put it on.
Edited by JimD - 21 Feb 2011 at 9:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 6:52pm
I tried the graphited packing string first... so far so good.  Thanks for all the ideas guys.
