Steering U Joint on a WD45
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: Steering U Joint on a WD45
    Posted: 20 Feb 2011 at 8:07am
My neighbor was asking me how to grease that u joint as he is replacing a NF with a WFE.  I always thought there was a zerk there, but it looks like the zerk is for the bushing that the lower shaft rides in.  SO, is there a way to gease or were these "factory sealed" u joints
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:20am
I don't believe the originals were greasable.
I replaced the cross and bearing kit in mine with Precision (NAPA) #861 which is.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:24am
Larry if the unit is not installed yet lay the u-joint at a 46* to 90* angle and look in the center of cross for a little plug if there's a plug just install a 90* grease fitting in it but if  it does not have the plug now is a good time to change the cross out. He can just remove the u-joint and add grease in the cups too
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:30am
thanks
