4w-220 tach repair
frankmi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Topic: 4w-220 tach repair
    Posted: 19 Feb 2011 at 9:40pm
Who are you guys using to repair tachs. I have a 4w-220 that has a working tach that does'nt read correctly. Ran low rpms before overhaul and now runs way to high after overhaul. Has a new pick-up so it isn't that! Name or number would be appreciated. Thanks   Frank/mi.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 7:12am
We just replace the whole tach.   How do you ike the 4W-220 have wanted one for years?
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 10:26am
IS it a electric one? I have one, nos, I can't use.
Allis orange blooded by family. Allis Diehard by choice
MUM FARMER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MUM FARMER Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 10:48am
Hi Frank wish I had a answer for you did they put a different flywheel in when you rebuiit the engine? If you get tired of your 4w and want to sell it I might be interested I have quite a few 4W220s  If you find a source to fix you tach I would like to find out I have several that arent working
monitordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 10:50am
 WHER DOES IT PICKUP SIGNAL? ALTERNATOR OR FLYWHEEL. DID YOU CHANGE BELTS , PULLEYS ETC. THE FLY WHEEL SENSOR NEEDS TO BE SET --I THINK--10 TO 13 THOUSANDTHS.
 THERE IS INTERNAL ADJUSTMENT ON ALL AC ELECTRONIC TACHS. IF IT'S CLOSE NOT RECOMENDED.
WD,D17-S4,180,D21
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:24am
8000 series tractors have a pickup over the flywheel ring gear teeth. Have you set the gap? Screw it in, then back it out 1/2 turn or so. I am guessing a 4W220 is similar to an 8070.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:30am
Wouldnt that one be mechanical drive?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 11:35am
magnetic sensor picks up pulses off the ring rear teeth on the flywheel. Programed number of pulses per revolution. I use ISSPRO's electronic programmable tach's on older tractors that were mechanical, or not high enough rpm scale. (210 AC 2500 tach, run 2800-3000 for pulling)
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:02pm
It is an electric tach. and the flywheel is the orig. one! The overhaul was done at an allis/agco dealer and installed there so I believe it was done correctly, they have done a lot of overhauls on the larger allis tractors. I believe it is the tach. cause before it would'nt hold steady on the rpms. Must be no one does repair on these? Thanks any way!   Frank/mi.
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:25pm
Have you tried looking through some auto magazines for like 60's and 70's cars?  I know there are a few shops that specialize in rebuilding that era's electronic gauges.  I can't imagine a tractor tachometer being a whole lot different in design from other electronic tachometers.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:33pm
AllisFields----How much are you asking for your tach.? (Does it work? Will it work on 220/8000 series?) Frank/mi. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:43pm
I think its for a combine, it is rpm and ground speed. dont think it'll work on 8000 series. try adjusting the air gap by turning the sensor in until it touches ring gear, then backout 1/2 turn and lock the jam nut. erratic readings could be the sensor  itself, or its adjustment, or wiring to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote monitordoc Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 10:15pm
 YOU SAY BEFORE IT DIDN'T HOLD STEADY RPM-- DOES IT NOW?  WHAT RPM DOES IT DISPLAY?  FIRST ADJUST THE GAP OF THE SENSOR  AND MAYBE TEMPORARLY REPLACE IT WITH A NEW ONE TO BE SURE OF THE PROBLEM.
 I REPAIR MANY OF THE ELECTRONIC A-C TACHS EVERY YEAR AND HAVE FOUND IT TAKES ALOT TO  WRECK ONE.
WD,D17-S4,180,D21
Post Options Post Options   Thanks (0) Thanks(0)   Quote frankmi Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:33pm
Has a new sensor. It has a steady needle but at about 3/4 throtle it maxes the needle out at 3000 rpms! Thanks Frank/mi.
