8010 starter
dale9570 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dale9570 Quote  Post ReplyReply Direct Link To This Post Topic: 8010 starter
    Posted: 19 Feb 2011 at 8:07pm
My 8010 has a nippodenso starting motor on it but when I turn the key to crank I get nothing.I can jump the starter solenoid and it will crank right over. Does the solenoid need to be rebuilt or should I take the whole starting unit and have it rebuilt?
thanks for any ideas.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:36pm
could be the start switch or the relay. If it works jumping the terminals at the starter solenoid, that proves the starter is working ok. Which terminals are you jumping to make it work? Are you getting juice to the S terminal(small wire)? good luck!  Ed.
chllngr528 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:38pm
I don't know anything about your particular starter but are you getting juice from the key switch to the S terminal? If you are get power to the S terminal then chances are the contacts in the solenoid are burnt up or corroded. On most big starters the solenoids can be service while the starter is on the machine. You may be able the pull the cap off the solenoid and clean up the the contacts or get a replacment set from a place that rebuilds starters. I just had a customer who wanted to replace the starter on his DT 466. I told him the starter was probably still good, so I took the cap off the solenoid, cleaned up the contacts, and flipped the  plate on the plunger and it has been running for the past 6 months with no trouble. I also just replaced the contacts in the solenoid on my cummins. A new starter was $300. The new contacts were $30. I don't have to tell you which on I opted for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:44pm
Just because you can jump the starter with a screw driver doesnt mean the solenoid contacts are good (unless your jumping the positive terminal to the S terminal). Instead of completing the circuit via the solenoid contacts your are completing the circuit with what ever your using the connect the terminals.
But if your not getting power to the S terminal your problem lies in the relay, key switch, or wiring
Edited by chllngr528 - 19 Feb 2011 at 8:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:54pm
Safety start switch on the clutch pedal or the safety start switch on the PTO valve.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 9:03pm
Pto lever in off position ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dale9570 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 9:32pm
I have power to the s terminal.clutch saftey switch is good.pto lever is off.will have to check pto saftey switch, can anyone tell me where to located the pto saftey switch.
thanks again for your replies
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 10:35pm
i remember all to well having to get off my 7000 when the wire came off the pto saftey switch, it isnear the valve body on the right side of the transmision. I will check the 8010 tomorrow and see if i can find it . Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:28am
Well if you have power to the S terminal on the starter while your turning the key that means the problem lies in the solenoid contacts.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 5:34am
On my 7010 PS, the safty switch was bad so it jumped it. Still nothing,so took the starter to the shop and the brushes were hung. The guy cleaned,new brushes and new contacts in the solenoid. Total cost of $42 and now it works great.
"Burgie"
