Convert my G back to 6 Volt?
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: Convert my G back to 6 Volt?
    Posted: 20 Feb 2011 at 8:29pm
I believe the G generator is shorter in over-all length than the B,C gennys.
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 3:18pm
Thanks, Bob.
Do you know if the generator used on the G was the same one used on the B & C? Was it used on other brands of tractors?
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 2:53pm
I took the 6 V generator off my G to a starter/gen guy. He said it was beyond repair. So I began looking for another. They seemed to be very scarce. So I took the generator to another, older, wiser starter/gen guy and he rebuil it. My point is that they may be very hard to come by.
Bob@allisdowneast
I used to think I was indecisive, but now I'm not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 2:45pm
Thanks Guys.
Now i'm still unsure about what to do.  I do like things looking origina and the whacked up sheet metal bothers me. I have a great starter/generator guy in forest Lake MN.  Think I'll spend some time with him.  Anybody parting out a G with used parts I need for 6-volt?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:49am
Dusty, I know the alternator from the Mitsubishi diesel engine in a Toro groundkeeper ZTR will fit. Was ready to toss it on, then sold the Toro. Being bored, I rebuilt the G's generator and tossed it back on. Maybe it's a CS110, cs100 ?? but the newer GM alternators should be doable, much smaller in diameter.
If I still had my G I could easily fab it up....bored with Winter again...
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 8:24am
I don't remember ever seeing a G with an alternator that didn't have the sheet metal altered.
Does anyone know of one that hasn't?
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 6:17am
Unless you're dead set on making it all original, I'd stay with 12 volt.One of the newer Chevy alternators (cs120 series,4 pin) should fit 'under the hood' without altering the sheet metal.Wiring of a G is very simple,easy to get at and not that difficult.Just take one wire at a time and learn as you go.Nice thing about 12 volt system, parts are cheap,easy to get.You can easily 'do it yourself' in an afternoon WITH a couple of coffee breaks.
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 10:39pm
first of all i wouldnt advise the switch. just clean up the 12 volt. the six is a lot more hassle than its worth and it just doesnt have the same bite...
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 11:13am
The 12 volt alternator would work beautifully at 6 volts with a special regulator made for 6 volts, but originally it had a generator which you need. And the associated 6 volt regulator. Wiring can't be terribly complex so a harness may be overkill unless its assembled with lots of loom or tape.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 11:05am
You would need the generator, a cut-out relay, the 3 position light switch, a "6 volt" coil and new light bulbs along with your new wiring harness. I would just about bet Steve B at B&B would have a package deal for you to do the change. I don't know what is reasonable to you but it won't be cheap.
   B&B CUSTOM CIRCUITS
          77 COUNTY ROUTE 519
          NEWTON, NJ 07860
          PHONE  (973) 632-5596
          E-mail: customcircuits@gmail.com
          Companye specializes in building wiring systems (6V & 12V conversions) for all early Allis-Chalmers Tractors. They also offer a complete line of electrical parts and
          accessories, along with Magneto, Distributor, Carburetor, Headlight 3 pos. switches, Starter, Generator, & Alternator rebuilding.   They build their own Battery
          cables, spark plug wire sets, offer our own reproduction parts and carry Fram filters in stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 10:41am
I have a G that was sloppily converted to 12 volt with an altinator, reused auto harness no switch and chopped up sheet metal. i'd like to convert it back to 6 volt.  I have a good starter but what other parts do I need?  Any advice on how to go about it?  I see three different wiring harnesses offered on e-bay...at least three with widly different prices.  Who offers a good harness at reasonable price?
