2 row corn planter hitch needed
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Topic: 2 row corn planter hitch needed
    Posted: 19 Feb 2011 at 9:49am
I recently acquired a 2 row AC corn planter, it was the one on Lima's craigslist.  It has the B/C type hitch, see photo below, on it and I would really like to convert it over to the CA pin hitch that it shows in the parts books.  I would also convert to CA or WD snap coupler style.  If anyone has a hitch to sell or trade for a B/C hitch let me know.  Oh, I could also use the assembly that the shoes attach to as one on here has a big crack.  I will try to attach pictures.  Thanks,
 Joe
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 9:50am
Picture of the broken shoe.
uploads/187/102_0908.JPG
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 10:56am
You are a couple years late, mine had a CA pin hitch on it, and I ended up buying a B/C hitch from orangereborn (Dale Schafer) and selling the pin hitch. OH is a lot closer than WI, but since I have some good friends, they made it migrate from WI to MN, to IA and got delivered 2 miles from my door.
Good luck finding the hitch you need, seems they are more common than the B/C ones....
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 11:41am
Joe, I have a WD pin hitch for one if that will help.
Don
tomdavison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomdavison Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 1:45pm
     Where do you live in Ohio?  I am interested in purchasing your B/C hitch if you want to sell it and you are not located to far from me.  I am in central PA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 2:21pm
Im in between Dayton and Lima, almost to Indiana.  But I'm sure we could work something out.  Id rather trade for the hitch I need, but I would sell it because it wont do me any good.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 2:26pm
Can that planter be converted to SC by simply bolting snap eye on tongue, are there lift rod's to connect to lift latches?
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 2:34pm
Chris,
The 2 row drill planter had at least 3 options for hitching. B/C tongue,  CA pin hitch, snap coupler. Also hitching options for WD were available. For all the little tractors, they used chains to connect to the lift mechanism. Due to the geometry of the hitches, all the tongues were different. You might be able to put a snap couple hitch on a pin hitch tongue, but definately not on the B/C tongue......
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 2:40pm
Thanks for the update, alway's learnin something!
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomdavison Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 3:30pm
  Joe, I sent you a PM  Tom Davison
This page was generated in 0.387 seconds.
