Can you run a WD-45 Loader off of the Belt Pully?
braskyku View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote braskyku Quote  Post ReplyReply Direct Link To This Post Topic: Can you run a WD-45 Loader off of the Belt Pully?
    Posted: 18 Feb 2011 at 10:56pm
Hello Folks,
I am wondering if I could convert my trip loader into a fully hydraulic loader with an independent hydraulic system running off of the belt pully. I saw a WD-45 on craigslist that a fella claimed he did this by adapting a hydraulic pump off of the belt pully. He used an auxilliary hydraulic tank and a two-way spool valve. He used a skidloader bucket. It looked like a pretty slick set up.
I really want a way to be able to operate the loader and the 3 point independently. I have got some advice in the past about using a valve in the hydraulic line but was cautioned that it was pretty darn dangerous.
What do you think? Is there a better way?
Also, I was thinking of changing my front wheels to car wheels to help with the weight.
Thanks,
David
1955 WD45 schwartz front end
DWC17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DWC17 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 5:24am
I put a front mounted hyd. pump on my D-17 to make my loader fully hyd. It works great and you can use the foot clutch instead of the hand clutch.
    Dan
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 6:51am
I think I still have a pump setup  like you are talking about. Mine worked good.  MACK
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 6:58am
I run my loader with a valve. Works good just make sure you get a valve that will handle the pressure. I have it mounted on the fender. A full hydraulic loader would be much nicer but the valve is less work to set up.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 7:26am
You will have to watch for clearance between the belt pulley location and the loader cylinders. On the WD45 you can not use the WD9 loader without removing the belt pulley because of the interference with the lift cylinder. Other loaders may have geometry that will let it work, but it is an area that needs attention.
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 7:47am
I echo Dan's recommendations. Did a front pump inst. on my B for the loader. Works great! The WDs are even better suited to the mounting of a front pump but you'd still need some machining capabilities or friendly nearby machine shop.
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:34am
my dad have one on his wd45 that ran off the belt pully . The loader had its own ind. hyd system on it . He used it for a lot of years
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 9:46am
I had that same intention and got a v-belt pulley, I think it was for a C and was supposed to be used for a corn picker. Correct me if I'm wrong. I think it's a 5/8 belt groove. I haven't done the loader setup yet, but I am still partial to the crank pulley live hydraulics. Economic issues gives me more time to think about it and not do anything yet.
You will have to match the pulley speed to the pump requirements to make it effective.
Steve Wilkens View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilkens Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 10:14am
I know there is a lot on this issue that I don't understand, but why can't you use the hydraulic system a WD or a 45 have and incorporate a spool valve? Is it because of pressure being too high? or not enough oil volune?Both?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 10:46am
I added a 3 way valve to my 45. Hydraulic pressure goes to the valve and is diverted to 1. the loader, 2 the remote hook up, 3 the lift arms. When the loader is about 3 ' off the ground I simply flip the valve to the back position and it holds the loader allowing use of the lift arms and rear blade. The only problem I could see with this set-up, is if I had a SC wheel disc. I would have to make the remote work with the lift arms, which would mean disconnecting 1 hose and attaching it to the same port as the lift arms.
 A 2 way diverter valve would work fine if you connect the remote and lift arms to the same port.
 If you want a hyd bucket you need to add valves and cylinders and it would be ideal to have a front mounted pump to run the loader. If you want to power the secondary pump with a belt, do it from the front of the engine like the power steering set-ups are done.
Edited by CTuckerNWIL - 19 Feb 2011 at 10:51am
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 11:01am
Just remember if you run the pump off of the belt pulley you still will not have live hydraulics.  Step on the foot clutch and everything stops.
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 5:47pm
What everyone is saying is true.  But remember if you use a front pump or one off belt pulley, this is a low pressure, hi volume pump.  You will need to change lift cylinders to low pressure cylinders or the lift rate will be slow. - AL
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 6:04pm
You can get a pump that puts out 3000+ pounds and most of the valves have an adjustable pressure relief valve capable of 3000 lbs. That should work with the Allis cylinders. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:10pm
45 Hyd pump unload pressure is 3700psi and most Ive seen are @ 4000-4200.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:17pm
Al, if you use a low pressure high volume pump the lift rate on Freeman cylinders would be way too fast and they wouldn't lift much of anything. Extending a regular 2 way cylinder with the Allis high pressure system would be slow. If a guy wants to make the bucket dump hydraulically, you just about have to have 2 way cylinders so changing out the lift cylinders would be a minor detail and would add usefulness to the loader having down-pressure.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 8:27pm
The best system going is still the distributor driven pump if you can find one. I see no real reason to spend the time with a belt pulley driven system which doesn't give you live hydraulics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 9:31pm
The distributor driven pump will wear the keyway out on gov. gear causing timeing to run back and forth and finely cut the key off.
  I have mounted a pump in front  of crank pulley. Not much room but enough.
 No need for a different oil supply, just add a tank under the frame plumed into drain hole of hyd system and return oil back into the added tank from added valve.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 9:48pm
How long would this take? There are thousands of M Farmalls out there with the live pump in front of the distributor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 2:54am
The WC/WD distributor pump setups were in service for a long time and I'm sure they will outlast the use most of us would ever give one of these old tractors. The bigger problem is finding one. There were a lot more units made for the Farmall that the Ac's. I've never seen one on eBay or for sale at a show/swap meet. I do know where there are a few units :).
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 7:11am
Where are they and how much for one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2011 at 7:42am
Live hydraulic pumpThis is on a Farmall Super M from what I can tell
Post Options Post Options   Thanks (0) Thanks(0)   Quote braskyku Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 12:54pm
Mack. Do you or anyone have a picture of that set up?
Thanks,
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote braskyku Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 1:19pm
Thanks,
David
Sorry. Just to clarify. I would like pictures of the belt pully set up.
Thank you,
David
This page was generated in 0.273 seconds.
