B question
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: B question
    Posted: 18 Feb 2011 at 7:27pm
Did the 39 B have shutters on the radiator?  Mine has a hole in the grill sheet metal for the crank to open and close but no shutters.  Don't know if the metal is original.   Tim
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 8:19pm
Mine doesn't... but I don't think that means they didn't.  Typically, shutters would be associated with an engine that would start on gasoline and run on distillate fuel... close the shutters to get engine temperature up, then switch to distillate... on a cool day, the engine would stay plenty hot, so the distillate would burn properly...
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 8:22pm
no shutters used on none presureized cooling systm. used a canvas curtin insted.  two stiles of curtains used . one prior to tr.# 22260 . -& one from tr. # 22260 to #43301 .    Shutters tr #43301 & up .
Edited by pumpkin man - 19 Feb 2011 at 8:27am
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 8:29pm
The early B had either the canvas( 37) or the shutters. They were used on both gas and kero tractor, The B didn't have a thermostat, and the engine ran better when the temp was increased, so they used shutters. My 40 B ( straight gas) had the shutters on when I got it. I haven't put them back on yet. I need a good crank, or I should take the time to remove the broken threaded rod inside the crank.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 8:33pm
My 1951 CA has the original shutters and has a thermostat. Gas engine only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 9:10pm
I think I'll weld a piece in the hole and finish up with body filler and not have shutters.  A working set might be hard to find.  Tim
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 10:29pm
Shutters were also an Option. Not always on every tractor. At least thats what I was told.
Bill Long, are you around?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2011 at 6:13am
No shutters on my B although the shroud has a hole for them. No sign they were ever there.
Charlie
This page was generated in 0.093 seconds.
