D-17 Series I power steering
tom in mt. vernon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom in mt. vernon Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series I power steering
    Posted: 18 Feb 2011 at 9:54am
I own a d-17 serial number 11243. I assume that this is a Series I. The power steering is out. I checked the level of the fluid in front of the radiator and it is full but milky. Do I need to change the fluid? How do I drain it, if I need the change? What fluid should I use to replace it with? Or, do I have another problem?
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 10:42am
The drain plug is on the right hand under side of the bolster. Refill with hy-tran, or ATF. Is your D17 gas or diesel ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom in mt. vernon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 11:45am
Gas, and thanks.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 11:55am
We had trouble with the pump on our series one, but we got it working, because a new one at that time (15 years ago) was like $1200.  Also had a D-17 Diesel in with milky oil, I changed that, and it worked much better, but it did work before i changed it too.
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 12:29pm
Dexron ATF was the original fluid & can be bought most anywhere. Fill to the point where there is 1/4 inch of oil above the flat gear as viewed through the filler/breather hole.  Bill
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom in mt. vernon Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 12:54pm
Thanks again for the replies. I've been trying to get the drain plug out but don't have my 3/4 drive socket set. Laid down under the tractor in some recent cat poo. Tried to use channel locks, ouch, busted knuckles. It sure is a nice day, 61 and sunny. Imathinkin' I'll just go fishin'. I've lived without the front end loader all winter. I'll let you know how it turns out tomorrow.
