AC 175 engine ???
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Topic: AC 175 engine ???
    Posted: 18 Feb 2011 at 5:52am
I bought an old junk 175 to play with, needs the engine changed.
Can I pull the engine without removing the side frames and front end ???
It looks that it could work. Something is wrong with this engine. Richard
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:04am
Richard, You got a good one there, do it up nice, you will be happy.
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:45am
looks like a good combine motor transplant prospect
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 8:16am
See if you can get a new Perkins block and put in it. Since CAT owns Perkins now paint the engine CAT yellow then you would have a CAT powered 175. As for an answer to your question I do believe you can but I'm an electrician not a mechanic.
If fishing is a sport your looking at an athlete
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 8:25am
I would like to purchase the cam shaft or complete motor if your going to replace that one.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 9:19am
Looks like a good start, kind of hard to tell but looks like you have big rubber, dual remotes and the factory top link.
