WD45 wide front
bilbo17924 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bilbo17924 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 wide front
    Posted: 18 Feb 2011 at 5:14am
I purchased what I thought was a WD45 wide front on EBAY.  That's how it was advertised. Paid $462 for it.  Long story...short, it doesn't fit.  The steering box that fits between the frame is approximately 15" wide....needs to be closer to 18".   The guy I bought it from, has basically told me to go pound sand.  At the very least, I'd like to try and sell it, but want to give it an accurate description...so someone can actually use it.  If not mistaken, the WD & WD 45 both have the same frame system.  CA and B have a different set up.  Not sure about a C.   Any help would be appreciated.   Thanks in advance.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 6:26am
A picture of it might help.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote bilbo17924 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 6:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote bilbo17924 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 6:39am
The picture is from the actual auction from which I purchased it.  It's the only picture I have right now.  thanks.
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 6:39am
Picture looks like a 45 WF to me.  I took out a 3 bolt and switched to a 4 so I know that can be done.  Dont know what to tell you.  And that seller is a moron.  Just keep leaning on him and hell cave.  I ordered some parts from him before and he screwed up the shipping.  Long story short I got a refund, but it took some battling.
Edited by Roddo - 18 Feb 2011 at 6:42am
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 6:48am
Looks like a WD45 4 bolt wide front to me.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 6:50am
Im stumped, too. Looks like a WD/WD45 front end to me........... keep us posted!
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:00am
That picture is poor, can't see enough details to comment. Take picture [ your own] and post so we can see what's going on. I assume you've tried/trying to install now, show us pictures of your frame rails, etc. Which model tractor are trying to install this WF into?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:00am
Wonder what a RC measures.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote bilbo17924 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:29am
Update:  I was too quick to say "seller told me to go pound sand", that was an assumption based on his lack of reply to my email to him.  I should not have included his ebay seller name on the picture.  I have since found his cell phone number and gave him a call.  He response was very favorable and he is willing to get me the 'correct' front end.  So....stay tuned.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 10:08am
by the looks of what is pictured that front end is a wd45 4 bolt wide front and will fit any WC, WD, WD45, and RC. I have not measured how wide they are. B, C, and CA all have different front ends.
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 1:21pm
I realize you may have gotten hold of Marty, but you will most likely (as others have said) keep battling him to get the correct front end.  He is a CROOK.  I have been tru it with him before.  Don't take his word for anything.  He burnt me once, but never again.
Adam
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 3:54pm
I just measured my WD45 Diesel narrow front. The casting is 18 5/8 inches where the frame rails attach.
bryan/silex View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 3:57pm
If that pic matches the front end you have it is the correct one, are you changing from a trike  front?  or why does it not fit? or what are you putting it on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bryan/silex Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 3:59pm
Also you do know that steering box fits into the frame rails?  the lip of the channel would be your 3 inches that you are off
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:22pm
Is the one he sent you the same as the one pictured in the auction?
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:44pm
Did you measure length instead off width.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 8:42pm
Bilbo,
I would say you are somehow measuring incorrectly.
The relationship between the width of the axle mounting plate to the width of the bolster itself appears to be just like the WFE on my WD-45s and any other I've ever seen.
I think a difference of 3" would be obvious to the eye, even in the picture you submitted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 12:01pm
Well, I wonder what ever happened.........................
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 5:57pm
I was looking at a seat assembly for a farmall 560 that he had. I could see in the pictures there was a piece of the seat suspension that looked broken. I asked several times if it was and he said it was perfect. I didn't buy it but felt sorry for who ever did. Look at his comments I don't think i would buy any thing from him!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote bilbo17924 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 11:46am
Update: I'm somewhat to blame (I guess).  I don't actually own the tractor that this is going onto.  I purchased it for a friend in the Upper Peninsula of Michigan.  I was not able to get to the buyer's place until almost 10:00 pm.  I had spoke to him numerous times and he actually had the front end hanging from hi-lo forks when I got there.  He was not there when I got there to pick it up.  I was not really familiar with the front end....I just lowered it onto my trailor and off I went.  Drove it up to the U.P. and dropped it off at my friends house.  Long story short...the wrong front end was hanging from the forks.  It supposedly fits a CA.  Not even close to a WD or WD45.  The seller is admitting his mistake and is meeting me with the correct front end half way between his house and mine.  I don't have it in my possession yet...but I think it will turn out OK, in the end.  Thanks for all the feedback.
This page was generated in 0.108 seconds.
