D-21 front hubs
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: D-21 front hubs
    Posted: 16 Feb 2011 at 5:43pm
i want to put some smaller wheels and tires on front end of D21 for pullin purposes, my question is what 5-6 bolt hubs will fit on axle?
Cowboy UP
JoeRepking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeRepking Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 7:02pm
they make a 15 inch rim that has an 8 bolt pattern that will work great!!!!!   we have them on our 210. we run a 9.5 15 tire on the rim and looks good!
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 9:08pm
the first d21 had 6 blot hubs and i think niel at north  d side has a set
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 10:12am
you guys ever get the rear tires swapped?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 11:12am
I have an L combine with 6 lug. After checking bearing numbers it would fit on most of the 7000 series.
