Homemade snapcoupler implements?
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Topic: Homemade snapcoupler implements?
    Posted: 16 Feb 2011 at 3:18pm
Have any of you ever made snap coupler implements like carryall's ect..
If you have could you post pictures.
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 4:56pm
My grandpa made a snap coupler brush hog from a old 3 point mower, but I don't have any pictures handy.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 5:03pm
I mounted a SC hitch from a junk 4 row planter on a heavy 3 point blade and used it for years. It made a good snow blade. I don't have pics either.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 6:04pm
I modified an old 22" breaking plow that the wheel trip mechanism was beyond repair to into a snap couple plow. It took several trips to "adjust" to turn soil behind the D17D, but we got it dialed in now. My D17D pulls it just fine. Removed the wheels, trip mechanism, and front end off the plow and welded in the front part of a parts snap couple plow. Sorry, don't have any pics of it on the tractor; maybe this spring. Sure does a great job turning big weeds and willow (which are plentiful in old ground around here). It will dig down 10-18 inches so the TB system is a real asset to keep it from going too deep. I found that 12" cut does well in breaking up the roots and rolling over a nice furrow.
powertech84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote powertech84 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 7:31pm
We mounted a fertilizer spreader on a cultivator. Used it like once and now it sits behind the shed. Would probly rather just have the cultivator now.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:01pm
I made this sprayer out of a four row cultivator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:28pm
Dad made a single spear big round bale mover out of an old 50 series plow frame.  And I bought a 2 fork homemade SC big bale mover from Don(MO).  Dad too made a 2 row potato digger out of old curved plow frames.  I remember having to stand on it as a kid to add weight to dig the potatoes up.  We also used our oxnard scoop frame as a make-shift 3 point adapter to use the 7 foot snow blower on the  D17 until I made a home made 3 point conversion in shop class in high school.  Mike
Edited by Skyhighballoon(MO) - 16 Feb 2011 at 8:29pm
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
ACMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACMAN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:57pm
We took a mounted two row cultivator off of our old 70 Oliver , then
made it into a snap coupler,  used it for years. also IH four row planter .
Dansen_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dansen_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 6:18am
I cobbled up an sc boompole from a 3pt one.  Not being into welding, I had to bend and drill flat iron stock, using a sc backblade to get the geometry right.  It lifts about 725 lbs.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 9:35am
Not snap coupler, but I adapted my IH 100 mower from IH fast hitch to fit the rear lift arms of a AC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 7:50pm
Mike this is the only pic I have of the bale fork. I got it from a old guy in North MO.
Don
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 9:02pm
I used a hitch from a plow to make this 3 point adapter for my CA.
DeWayne
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2011 at 9:06pm
Very nice three point  adapters.
mike 44 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike 44 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 7:45am
i made a sc corn planter for my d-17..... and going to make a sc snowblower and maybe a carry alll this year
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2011 at 10:04am
I converted a 3 pt. bush hog to Snap Coupler that I use behind my WD. No pics now as it's under two or three feet of snow!
