Marvel Schebler ID
chickenmann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Topic: Marvel Schebler ID
    Posted: 15 Feb 2011 at 5:31pm
I have recently bought my first Allis Chalmers equipment. It is a 1945 C with a Marvel Schebler Carb on it.  I cannot find a number on the carb anywhere.  I need to find the number so that I can order a rebuild kit for it.  Was the number on a tag or the carb itself.  If on the carb, where should I concentrate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:06pm
Any help...Anyone?  Any suggestions are appreciated.  I have wirewheeled and scraped and am at a loss.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:11pm
There should be a small tag attached with the #,  probably held on with on of the bowl screws.   Going from memory I think mine was on the back next to engine.  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:13pm
Thanks Tim,
Tag is gone.  Is there any other way to figure out which carb I have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:18pm
Sorry, I used all the carb knowledge I have...  Maybe Steve B, or another member with more experience than I will chime in.   Tim
chllngr528 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:26pm
If its a Marvel Schebler it has little round tag with a rivet or stud in the center of it. Its located on the right side of the carb ( the side with the throttle and choke linkage) and should start out with TSX....... My book claims that the model C came with a zenith 61AJ7 or 161J7 but it wouldn't be the first time this book was wrong.
Edited by chllngr528 - 15 Feb 2011 at 7:28pm
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:27pm
Kevin !!  If you  have  a 44 -C  it  could have  a  TSX154     Carb.
 Tag should be on upper body facing air  hose.     Tony
Post Options Post Options   Thanks (0) Thanks(0)   Quote chllngr528 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:27pm
I think it was the zenith carbs that had the tag attached to the bowl screws
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:40pm
Hey Guys,
The rim where it attaches to the manifold says Marvel Schebler and that is the only marking on the carb.  Someone apparently lost the tag before I got the tractor.  The serial number on the tractor is 32768 which I believe is a '45 model from the serial number lookup on this website.  There is an H on the bottom of the bowl and a small circle with a letter in it but I can't tell what the letter is.
Kevin
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:48pm
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:54pm
you will find there is only 1 rebuild kit for Marvel carbs that  fit C, B, & CA. the guts are the same. Bob
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:55pm
Let me offer a slightly different thought that may or may not help.  How much are you replacing in your carb rebuild?  If you are just doing gaskets, a good cleaning, float needle/seat and even throttle shafts, a kit for the number Tony mentioned will work.  It's when you start wanting to replace power needles and such that is when the different models will come into play for tuning.  HTH Ryan
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:55pm
Thanks Stu,
Looks like maybe someone replaced the carb at some point with one that is incorrect.  I guess the next best option is to buy the correct carb and put it back on the tractor.  Looks like a Zenith 9705 might be the ticket if I can find one.
Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 8:01pm
Chalmers Bob and Ryan(TN),
Y'all may have just saved me a bunch of money.  I am only doing a clean up and basic rebuild, nothing extensive.  I am going to go the cheaper route first and get the kit Tony suggested from Tony and try that first.  Last resort will be to replace the carb.  My only fear is the drain plug on the bottom of the carb is broke off in the carb and mayh need to be replaced to get it really clean.  Tractor sat for 10 years and is full of varnish.  Have it soaking right now and hopefully can get it working again.
Kevin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 8:03pm
Just because they list only zenith, the marvel was used also. If it fits, it will work. It is a simple carb with a fixed main jet and other then replace shaft seals and a float valve, the bigest thing to do when rebuilding is clean, clean, and clean again. Sure some parts wear out, but mostly it will require a good cleaning. I never found one that couldn't be put back in service after a good cleaning. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 8:07pm
chalmersbob,
I am going your way, Clean, Clean and more Cleaning, put it together and see if I can bring some old metal back to life.  Thanks so much for the help all of you guys.  This forum is an unbelievable resource.  Would have probably already scrapped my tractor if it were not for the information here.
Kevin, the chickenmann
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 8:24pm
the plug that is broken is only a drain plug. It's not necessary to remove it to clean the carb. If you want to remove it, drill it out with a drill, (if you a have left hand bit , great). start with a small bit and as close to the center as possible, and keep inlarging it but stop before you hit the threads. then with a small chisel remove the remainder of the plug. It is a 1/8" ( or 1/4") pipe thread plug and can be gotten at any hardware store.
Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 9:10pm
Here is an exploded view of your carb under fuel system:
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 9:25pm
Tony is right. The TSX 154 off my 1950 C is soaking in carb cleaner now. HTH
Lanny  Middle TN
Post Options Post Options   Thanks (0) Thanks(0)   Quote chickenmann Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 9:44pm
Thanks so much guys,
Kevin
This page was generated in 0.104 seconds.
