8070 FWA
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Topic: 8070 FWA
    Posted: 14 Feb 2011 at 8:33pm
Have a new set of tubeless bias ply tires on the front of my 8070FWA.I will be running in a field with mesquites this summer.I have heard that running water in tires will help from having flats.When the thorns go in the tire the water will swell the thorns and they want leak as bad.I know on the rear tires this is true.Will the added weight hurt the wheel bearings? The tractor has a full set of front weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:43pm
First of all, there is no added weight to any bearings....it's all in the tires. Second, half-full of water should accomplish what you want, shoudn't it?? Third, if you are adding 500 lbs total of water, take 500 lbs of cast iron front weights off....even steven. Then, after you figure out how nice it rides going down the road with little or no bounce anymore, you'll just leave it that way permanently.
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:12am
They make tire sealant for that. Walmart sells green slime. I have that in fron tires on my kubota and in fourwheeler tires. Works great. Bill
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:40am
I have had the best luck with the green slime.  Mesquites are murder on FWA tractors and usually win in the end.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 6:11pm
 We had a FWA Ford tractor that had fluid in the front tires and all four of the back ones and about 3300lbs of weights on the front. Best riding tractor weve had for going down the highway. Never used it before but genseal sounds like good stuff. heres there website.  http://www.noflats.com/genseal.htm
