ID Gary's disc
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: ID Gary's disc
    Posted: 14 Feb 2011 at 8:03pm
I couldn't find his original post so here is a new one. What model is this disc?
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 8:46pm
Looks like an A-C 200 series disc to me.
Matt Folkers
FOLKERS RESTORATION
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:09pm
I'd say a 210....200 series, 10 ft wide.
ALLIS EXPRESS!
This year:
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:20pm
You guys are right again it's a 210. Looks nice but she is missing the depth stop stuff and the chain lift stuff for the weight transfer too but the rest of it looks good.
This is the best shot I can find of my 10' disc.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:49pm
I have that exact same disc, definitely a 210 although mine sits nicely on a 102 inch trailer without hanging over too much. Pefect disc for a WD45, it will do a nice job and if you are pulling hard will make the 45 snort.
Gary(VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(VA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:07pm
Thanks for the replys. I picked it up last weekend. It needs one bearing. What kind of parts are available? Also looking for the chain assembly or good pics. of one so I can make some.
Thanks for any help.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:23pm
   I have looked at this style and wonder can you turn very tight ? Look's like the tire would hit the tongue pretty easy.
http://www.rumelyallis.com
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:29pm
I have wondered the same thing. I have a 210 that was converrted to drawbar hitch when I got it. I have a snap coupler eye that I could put back on it. I would love to see some close ups of the traction booster chains Don!
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 5:33pm
The first row of gangs looks like it comes closer to the tires than my older #11b does.  So I'd imagine you'd need about an acrea to turn it lol.
Edited by OrangePowerGA - 15 Feb 2011 at 6:20pm
AC - WD
JD - 650
RickM(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 6:25pm
The picture that Don posted is my 45 and Don's disc with Charlie Tucker driving and me on the fender. We didn't have the wheels set exactly right for maximum clearance when turning, which is why I was watching whenever we made a turn. We didn't stop to reset the wheels since we were going to switch back to plowing after a couple of rounds. I don't remember if the wheels should have been set another stop in or out. It would have turned tighter if we had taken the time to set them right. By the way, the Traction Booster hitch really worked well to add traction in that fresh plowed ground. I was also trying out my transport valve to see if it worked and it did.
Missouri Allis Chalmers Club Member; 1954 WD45 (NF), 611LTD & 811GT Lawn Tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 6:54pm
The bearings are going to be high but they are available. Here's two more shots of it, I'll try getting some closeups of her tomorrow before it gets dark. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:06pm
Thanks Rick for posting about the disc.
And yes we didn't set the rears out to the right setting for it to work good, that was my fault.
I just looked up the rear wheel setting in the book it said 75" to 80" and you still need to look at the disc when turning at the end. The fun part is trying to back it up. lol
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:41pm
Yep, you gotta watch the turns but if your traction booster is set up and working, I don't think you could beat this set-up for plowed ground. Rick, I'll trade you tractors anytime you want. I have PS in my 45 but Rick's worked a lot better. Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:50pm
Charlie I told Rick that me was getting a good unit. lol
Did you fell the difference in how the disc pulled with the traction booster transport valve turned on?
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2011 at 8:16pm
For sure Don, you could bury yourself in fresh plowed ground without the TB.
