auction today
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Topic: auction today
    Posted: 14 Feb 2011 at 5:47pm
I went to a sale today and there were 3 pieces of AC. a 95 ground drive manure spreader , a 6 hole AC wagon running gear and a 56 wd45, I brought the wagon and manure spreader home but someone else got the 45, does anyone have a ground drive 95 they would sell parts off of,  I need the big drive gear on the left side axle after I got it home I noticed that it was missing 7 teeth and 6 of them are in a row I could fix it but would like to buy a good one if anyone has one, Thanks,Dustin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 6:34pm
What did the 45 go for?  Did it have factory PS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 7:12pm
the 45 sold for 1000.00 but it didnt have ps, NF, it was pretty original and the tin was good except for a fold on the front right side of the hood and one fender was a little bent, the bad thing was it had set for quite a while and smoked when they fired it up.  I bought one about 2 weeks ago it was a 57 NF and had the factory ps and is wearing her orig paint and is verry straight, it had a saganaw 3pt hitch, I got it for 1200.00 and sold the 3pt off of it for 300, so I only have 900 in her now I think it is a pretty good deal
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 8:44pm
Dustin,  What AC model number is a 6 hole wagon gear and a 8 hole wagon gear?
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 9:44pm
    Hello Eric     The models  per the bible   are  #305  =3 1/2ton economy    #405 =4 1/2 ton  5 hole,  #505  =5 1/2 ton 5 hole,  #6 1/2ton 6 hole,  #701  =7 ton for power feed boxes,  and #1001 10 ton for hyd hoists.   Electric Wheel  made the gears for AC.   We have 4 AC 605 gears with 8' x18'  wood cut from electric poles, 1 barge box with hoist, and a flare box on a hyd gear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 6:20am
Allen - thanks for your specs.  You must have a brochure for them or manuals.  My Norm Swinford AC 1914-1985 list some info but not a lot of specs.  So, the 8 bolt wheel gears would be the 701 & 1001 - or just the 1001?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 7:40pm
Hello Eric  I think the GOOD brochure is out in the barn, the old brochure doesn't list the 701 or 1001, if I can find it i'll try to email it  Allen
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:39am
Allen Dilg, any luck finding the 701 or 1001 wagon brochure?
