shifter wd45
jhornpa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jhornpa Quote  Post ReplyReply Direct Link To This Post Topic: shifter wd45
    Posted: 12 Feb 2011 at 12:32pm
locking in 3rd gear will new pivot pins and shifter fix it. looks like they are wore but forks and gears look fine
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 2:47pm
Its been a while, but I welded up the end of the shifter and reground it to the shape I thought it should be and made oversize pins for the tower.  If I remember correctly, I made the pins from grade 5  5/16" bolts and ground the heads to get a good fit in the shifter slots. Have never had a problem since. Of course, if you're not cheap like me, I believe you can still purchase ovewrsize pins and a new shifter from Agco?
