Narrow front end 720 lawn tractor
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: Narrow front end 720 lawn tractor
    Posted: 11 Feb 2011 at 7:30pm
I brought up the idea of installing a narrow front end on an Allis Chalmers 720 a few weeks ago. My mechanic friend who can do almost anything call it another of my "Nightmares".  Well we tackled it and it is near completion.  I took it out Tuesday for a run and it steers great...I like it.  I usually seek out narrow front end tractors so this goes with that train of thinking. I still have 3 with the wide front end still on them and this one is totally reversible as the front end is bolted on...not welded.  Here's some of the progress in pictures.
This first picture is where we made a bracket to accept the mule drive for belly mounted equipment.  We are going to be able to run all the belly mowers as before.  We are using a left over frame from a salvaged tractor to mock this up on and then transfer it to the real tractor.
Here Kerry is lining up the narrow front end to continue fabing up the front end.
Here is the front end with it's first bolting to the front end.  The pulley on the top of the shell was to help line up the belt to the mule drive.  We did not need it as we will keep the original body of the mule drive as is but have to remove the tension-er.
Now with the steering connected.  You can see some of the additional front end bracing that we added.
Here's the front end attached to the subject tractor.
Got the engine remounted
And now a series of pictures of the finished product.
This one with the mule drive installed
Next step is to repaint the entire machine.  While the paint in the pictures looks good...up close or in person it is in pretty sad shape.  Once painted, I'll put the sickle mower on it and be ready for spring mowing and also for this years shows.  Thanks for looking.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 7:52pm
You may want to "beef up" that pedestal a little though. Looks like it would easily bend or break if subjected to any accidental amount of force. Looks awesome though!
just my 2 cents.
Luke
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 8:10pm
Luke,
If you could see what is under there you would most likely change your mind.  Kerry overdoes things like this and I would not be afraid to take that machine anywhere.  It is of course like any narrow front end machine...I have heard of people braking the front end off a WD.  Abuse can do make a mess of the best engineering.  Den
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 8:26pm
Den - Looks good.  My only comment is why such small front wheels.  Looks like 8", could have used 10 or 12"
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 8:38pm
I agree on the size of the wheels, but it looks like it's pretty close to that bracket already and if you would have used larger wheels/tires, it would have to be mounted further out for clearance and probably wouldn't look right.    Would have looked out of place like a Case SC? narrow front
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 8:44pm
Is that the 720 we sold you? I think it would look great with 8-16 ag bar tires on rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 9:16pm
Al and Chuck...Larger wheels would have eliminated the use of the mule drive or as was said, moved the wheels forward.  If we moved the wheels forward, the hood would not be able to be opened or would have had to been altered.  One priority in this project was to keep the usage of the belly mounted equipment.  And no...did not want it to look like one of the old  "chicken roost" case front ends.
This is the 720 that I got from Dale Garver at Ava, Illinois.  Yes, rear ag tires will go on with the sickle mower.
Keep the comments coming...Den
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 9:23pm
Den   Looks like you have done great job with a lot of fore thought going into the project.Thanks for sharing.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 9:34pm
Not too shabby.... I was kind of surprised to see this project actually happening!  Glad someone here has more ambition than me this winter, LOL!  Though I think larger wheels would look better, I understand the logistics of it.  Good work, keep us posted.
So, what's next?
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Steve M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 9:39pm
That's great, it's neat to see one thats not  "green' or "red".  After doing some projects like this myself it really makes you appreciate engineers a little more.  Tire size, location and other such things that can really screw you up if not thought out clearly and then theres still some trial and error to it. Seems like theres always some give and take to what you really want and what will fit or work when finished.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 9:51pm
Besides putting a narrow front end on this tractor...the main thing was to keep it in use.  We have all seen other narrow front ends on garden tractors but in most (if not all cases) cases the use of front and belly equipment was lost.  As far as this one...could not (or want to) put the loader on it.  Not sure about the front blade and also doubt that the snow blower would be able to be used.  Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 9:53pm
Oh, what's next....still want a snap coupler 720.  It will happen if I live long enough (like another 20 or 30 years?).  Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 9:55pm
Well this only took a couple of weeks, so I'll be looking for the snap coupler the beginning of March, LOL!  keep it up
Jacob Swanson
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 10:37pm
I like it...I think you should call it a 720XT!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 11:12pm
Actually, if you already have one with a 3pt, a snap coupler wouldn't be much of a task besides maybe getting the bell receiver to function properly. I think there are single bottom snap coupler plows out there, or at least a two that you could remove the  second from. Or, you got a mechanic to build ya one. I challenge you to the Task!!! LOL
German Shepherd dad
#WD234847
#WD88193
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 4:29am
Den, Now that is sharp. Will have to make sure I remember to scope it out my next trip to your place. Just store it beside those tires your holding for me. LOL I'm absolutely certain I would not mistakenly load it up thinking it was my tires.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 9:23am
Den, That's just plain cool! The front end looks like it's built to take the weight of a blade. GOOD JOB!!!!
Don
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 10:53am
Put some rubber on the the back, some weight brackets on and see what it will do!
Probably not much with the twin belts driving the pump.
What was used for the front spindle?  My gears are starting to turn.
Edited by JoeO(CMO) - 12 Feb 2011 at 11:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 7:56am
Joe, front spindle is from a "G" front end that I could not get ride of...cut in two, shortened and put back together.  There are parts of the 720, "G:, C, and fender brackets from a D 17 involved in the front end.
The slow down in snap coupler on the 720 is that I'd like to do it more to scale and then there's converting equipment to snap coupler.  It may happen.  Den
AC720 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 6:49pm
Nice looking AC720!
It really looks unique with the narrow front end, now it just needs its bigger brother, unless you own a 190XT narrow front end.
Take Care Jason B
bigallis1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigallis1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2011 at 8:17pm
Nice Den!
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2011 at 9:39pm
Bump. Is this the one you're looking for Larry?
