7010 Hi - Low lever
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Topic: 7010 Hi - Low lever
    Posted: 11 Feb 2011 at 4:38pm
I looked at a 7010 power director today that is for sale near me. It was a very clean nice machine. The only problem I could find was the Hi - Low lever on the far right, next to the cab wall, shifted VERY hard. The seller said it is probably the cable. Could this be a more serious problem?
He came down to $9,000.00 and the tractor has about 5,300 hours. What is the most a 7010 could be worth. What did a 7010 sell for new? Any insight would be apprieciated.
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 5:26pm
It can be the cable, they do go bad over time.  The only real way to tell is to unhook both ends and see how stiff it is.  If that one is going out, be prepared for the clutch cable to go next, and depending on the remote hydro use, those can go to, but ge the new AGCO cables, they are a lot better these days, much more resistant to dirt and moisture.
9K seems really high for a 7010, depending on the year and condition.  Most dealers think the 7000 series tractors are worth 9K - 15K, but on the private party or auction block market, I would think 5500 to 7000 for a really nice one with low hours.  5300 hours is getting up there, but nothing to worry about if it has been taken care of.  Our 7060s averaged 9000 hours before the first teardowns.
Edited by Orange Blood - 11 Feb 2011 at 5:26pm
Still in use:
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 6:07pm
It can definitely be the cable.  My 7060 shifted from high/low to park very well in the summer, but now that it is cold it doesnt like park.  Changing/lubing the cable is on my list whenever it thaws out.  Its hard to believe how much easier one shifts/clutches after the the cables have been swapped out.  I think 9k is high for this part of the world also.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 7:53pm
My friend Donald bought his 7010 2years old .a couple of years ago and with over 10000 hours he had the allis / aco dealer rebuild it. front to rear. every seal that leaked, power shift loked over. All allis parts in the motor. new turbo. new cab kit, seat,gaudges, had a high end paint job. new radial tires. Over $22,000 later. Now It's his pride and Joy again.
Edited by Allis Fields - 11 Feb 2011 at 7:54pm
Allis orange blooded by family. Allis Diehard by choice
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 8:50pm
If it is nice shape, I don't think 9 grand is out of line. It is towards the high end of the spectrum, but should be a very good all around tractor with good fuel economy. Just my opinion though, Darrel
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 10:15pm
we've had them around since they were new.  i have 2 7020's now.  only problem i've seen is the 301's have warped heads.   don't let them talk u into new or rebuilt ones without taking them to your machinest.   the last 3, all i've had to do is have them planed.   just watch how far and you won't even need to reheight the valve's.
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 7:27am
I also would think that $6-7K should be able to buy a 7010 with 5300hrs.  The current problems associated with the used farm equipment prices is the higher price of scrap iron & high dollar commodities - $7 corn & $14 beans.  There is a sqeeze coulper inside the console that my 7060 needed repaired.  It had 2 bolts, one had snapped & the other backed out some.  Easy repair, but hard to get to.   I also replaced the T-handle shift cable.  Same kind of repair.  Another item to watch - I would check the cab air conditioning.  On a 1979-80 model, you might want to figure replacing the compressor & condensor because of the decades of vibrations on the system.  AP air inc in Iowa carries this replacement kit http://www.apairinc.com/detail.asp?part=990-005.  I put one of these on my 7060 & was glad I did.  I don't remember what I had in it on cost, but you should probably call for current pricing anyway.  I think I also had to put a new condenser in front of the radiator.  It had a leak in its fittings.  When I tried to correct it, the whole fitting twisted off - so had to get new.  Good luck - You can always make an offer?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 7:29am
I failed to mention that the squeeze coupler in my last post was on the high/low cable.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 7:55am
Around me that's about what a nice one would bring at auction before the high crop prices.
Edited by Lonn - 12 Feb 2011 at 7:56am
Wink
I am a Russian Bot
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 9:23am
I don't think 9000 is that bad if it's in good shape. I've seen them go higher than that.
