14 x 38 Rims
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: 14 x 38 Rims
    Posted: 10 Feb 2011 at 4:51pm
Did any manufacturer make a pressed steel rim with centre, that would fit on a D17. All the pics of AC's that I see with 38's are on powershift rims. Or where can I buy them new. I am putting 15.5 x 38 on the D17, and want to keep it in the 4500 lb class.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 4:58pm
I built a set out of 9 bolt duals. I cut the center out and welded a 8 bolt center in it. They work great. Ive seen a few pics on here of them on pullers, they might chime in and give more advice. With them on my D17 wide front I can only get it to 5000 if I remember right.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 7:50pm
Brian, I have 14.9 x 38 power shifts on my D-17 iv. The centers came from a Massey 65 high arch and are identical to the originials that were an option on the D-17's. Any Massey  8 bolt pressed steel rim will work. Maybe you can find one from a M-H 33. Good Luck
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 8:58pm
i have a pair with centers and nice rubber on them thansk p.m if interested. thanks ben.
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2011 at 6:56am
Did gleaners have 38's?
alliswd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alliswd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2011 at 7:06am
I just ordered a new set of 14x38 rims with stamped centers so I could put 15.5x38s on my WD puller.  I had two options - have them take a set of sprayer rims (10x38) and have them widden them.  Or, take a set of 14x38 rims and weld a dual wheel center in.  I chose the later, even though they are ~50 lbs heavier each.  I run wheel weights on my 14.9x28s any way, so the weight won't hurt.  Plus, I didn't like the idea of two full circumfrential welds for the spacer on the rims, and, I got exactly the backspacing I wanted so that the tractor still fits on the trailer, and clears the fenders.  They were NOT cheap though.
This page was generated in 0.158 seconds.
