AC-200 HP
Big Al 485 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Topic: AC-200 HP
    Posted: 10 Feb 2011 at 11:53am
Hello all,
I am looking at an AC 200 and am confused about what the real horse power is. I see that some are listed at 93hp and some are listed at 106 hp. Is there a model with a turbo and one without, hence the different ratings ?
Thanks
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 11:55am
The model 200 was never tested and was sold on the 190XTs rating of 93. Many of them are producing more than that. Ours has 110. All 200s had a turbo.
Edited by Dans 7080 - 10 Feb 2011 at 11:56am
sandylakeimplement View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandylakeimplement Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 12:07pm
There were some minor differences in the factory ratings depending on whether the pto is 540 or two speed. Such differences would be only slight. You are likely seeing one that was merely a factory rating and others are actual dynomometer test readings. Any 200 worth it's salt will dyno at 100 hp minimum.  Bill at S>L>I
Sandy Lake Implement
Sandy Lake, PA
724-376-2489
www.sandylakeimp.com
FIND US ON FACEBOOK
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 1:40pm
Mine is 120 plus.
"Burgie"
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 3:11pm
Never tested. Allis used the XT data but the engine improvements gives all 200's higher hp. At least that's what I read in Norm Swinford's book. At the Allis shop I used to work in the older mechanics told me they never dynoed a new 200 that didn't put out at least 110 hp.
Wink
I am a Russian Bot
